Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: integy 55 stalls out
Old 04-02-2008, 08:51 PM   #1
Default integy 55 stalls out
Hi,
I got a clod with two integy 55 9t pinions.
When I try to go up something really steep the front tires start to slip and keep turing, but the rear stalls out and won't turn.
Dont get me wrong, my set up seems to have a lot of power, but shouldn't it keep turning until the car flips over backwards?
I am running a traxxas ECS 14.4v from a emaxx 4s1p lipo on one side with a seperate 6v reciever.
Thanks
rmasu is offline   Reply With Quote
Old 04-02-2008, 08:55 PM   #2
i bet if you search this section for "clod stall" you will find a lot of info on that problem
4stAir is offline   Reply With Quote
Old 04-02-2008, 10:42 PM   #3
TCS/Holmes Hobbies
SVEN's Avatar
Originally Posted by rmasu View Post
Hi,
That is the best thing about clod stall. The truck doesn't flip as easy as a shaft driven truck when climbing. If you learn to use it to your advantage, it can be very helpful.
SVEN is offline   Reply With Quote
Old 04-02-2008, 10:52 PM   #4
Rockcrawler's Avatar
X2 You can also run a 8 tooth pinion in the rear to take a little of it out.
Rockcrawler is offline   Reply With Quote
Old 04-03-2008, 12:50 AM   #5
Building Not Buying
CD13's Avatar
X3,it can work for ya too.I have dug up on the rocks till the rear works without rolling over but I have had it come back to soon and cause a flip.
Put a smaller pinion in the rear or run 2 esc's with a lot of voltage will make it better.
CD13 is offline   Reply With Quote
