Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: My clod tuber build - finally!
Old 04-18-2008, 12:16 PM   #1
Southern buggy whore
ecoli's Avatar
Default My clod tuber build - finally!
I've had axles and wheels sitting waiting to be built up for a long long time (since last June or July I think!). Too many other priorities (like changing around my 2.2 rig on a seemingly constant basis!), but I'm nearing completion so figured I could start posting up some progress pics. This thing is going to get finished this weekend, no matter what
Specs:
Axles: Stage 3 RCP axles (full bearings, aluminum lockers), JP steering knuckles, Thundertech wideners/adapters, aluminum upper link mounts
Wheels/tires: Proline Moabs on narrowed Cheyenne beadlocks (yes, I know the front tires are on backwards!)
Chassis: Tuber, obviously!
Links: 3/8" delrin with Jato and Revo rodends, connected with 8-32 allthread. Steering links are solid 1/4" aluminum with stampede rodends.
Shocks: Traxxas 4" big bore aluminum
Motors: 65 turn Integy with 7 and 8 tooth long pinions (I think that's right!), mounted with adjustable motor mounts
Servos: Towerpros (945 if I recall correctly) mounted with Integy mounts
Esc: Novak Rooster Crawler, hooked up to CC BEC
Radio: Traxxas TQ3 with modified rear steer switch
And the pics:
Still have the electronics to go. All the links are now mounted up and the shocks temporarily mounted, and panels are done so only a little more to go! Ride height will sit around 4.75", wheelbase as pictured is 17.5".
ecoli is offline   Reply With Quote
Old 04-18-2008, 12:56 PM   #2
Location: where fear and common sense don't get in the way
Looks great .
jagg is offline   Reply With Quote
Old 04-20-2008, 04:04 PM   #3
ecoli's Avatar
It's all done, and pics to prove it:
Plenty of room in the belly pan for esc, rx and sub-c six pack if you so chose to run the batteries there.
Good amount of flex without being too excessive.
Wired it all up, plugged in the battery, calibrated the esc and what do you know, it worked! Of course, all the snow kept me from trying it outdoors. Just ran it on the carpet, up the stairs, etc. Supers truly are giant beasts of crawlers. Too bad nobody else runs them around here.
Old 04-20-2008, 10:30 PM   #4
Gavyn is my BFFL
Nabil's Avatar
im loving the chassis
Nabil is online now   Reply With Quote
Old 04-21-2008, 04:17 PM   #5
Looks good! Love the carbon fiber panels. I keep thinking I should try to build a tuber, but I am not sure how to set it up. I have just started crawling and basically built a chassis out of some aluminum I had laying around and used some Clod axles from 15 years ago. I have now caught the bug and want to start improving on this mess. Since this is all new to me, I am wondering if you could give me a measurement. I am looking for the amount of seperation between the upper and lower links on the chassis. I am trying go get a ballpark figure so I can build a little adjustment into it without having to drill ump-teen holes that I don't need.
Thanks, Barfnick
Barfnick is offline   Reply With Quote
Old 04-22-2008, 11:50 AM   #6
ecoli's Avatar
Carbon fiber stickers . XXXMain makes them in 8.5x11 sheets. In photos, it looks pretty realistic.
As for the link placement, I think they're about 1.5 inches apart, but don't quote me on that. A good thing to do is to get a bunch of pipecleaners (the dollar stores usually sell them in bulk packages) and do some mock-ups that way. I almost always do drawings on paper for my tuber builds. For my 2.2 builds, I have 11x17 "templates" with the wheels drawn on at a 12.5 inch wheelbase. I then draw in various lines to indicate where my shocks and links mount, and where my clearance is for servos (if I'm making a longer chassis). Picked up this trick from Double J. Planning pays off!
Thanks for the feedback guys.
Old 04-22-2008, 01:04 PM   #7
Depends on where "here" is, your location only says Canada.
Old 04-22-2008, 01:47 PM   #8
ecoli's Avatar
Come on, Canada's only the second biggest country in the world
Red Deer, Alberta. I have a hard time finding people with 2.2s, never mind supers!
Old 04-23-2008, 04:10 PM   #9
Thanks for the tips. I will need to decide about how long of a wheel base I want and go from there with some rough sketches.
Old 04-23-2008, 06:20 PM   #10
Hey there's lots of 2.2's and a few supers down in calgary. Check out calgaryrc.com for times when we're crawling maybe you could come down?
spinner is offline   Reply With Quote
Old 04-23-2008, 06:33 PM   #11
What are the differences between the 2.2's and the supers?
dleigh007 is offline   Reply With Quote
Old 04-25-2008, 03:18 PM   #12
Tire size, and rig size limitations.
http://www.usrcca.com/rules2008.pdf
Only applies to compitition rigs.
sp4mike is offline   Reply With Quote
Old 04-25-2008, 06:30 PM   #13
ecoli's Avatar
And now there'll be one more, Jester put down a deposit on it today and has me working on another project for it.
I'll definitely come by Calgary at some point. Although with gas prices, I might have to bike
Old 10-24-2008, 08:45 PM   #14
nice build
Vanman is offline   Reply With Quote
Old 10-26-2008, 11:05 PM   #15
who made that tuber? more important, is it for sale anywhere? thanks, looks good
bullet1231 is offline   Reply With Quote
Old 10-27-2008, 01:59 PM   #16
ecoli's Avatar
This thread is a bit old, I was suprised to see it brought to the top. Anyways, I made the tuber but it has since moved on to another owner. I am a vendor here, so can always make another one to sell.
