| | #1 |
| Newbie Join Date: Nov 2005 Location: south jersey
| I had my clod setup pretty good with a 3000mah 6-cell, 2 65 turn integy lathes and 6th pinions with stock size tires. I recently upgraded to 40s mudslingers and the truck has considerably less power. How should I fix this? will adding a cell to the pack help? different pack? motors? BTW I'm runnin a rooster esc. |
| Sponsored Links | |
| | #2 |
| Day By Day ![]() Join Date: Nov 2006 Location: spring hill TN
| 3-cell 4500mah lipo and 35t motors with the 6tooth pinions works great. |
| | #3 |
| I wanna be Dave ![]() Join Date: Oct 2005 Location: Columbia TN
| Just swaping to 35t lathe motors will net you a considerable power gain. |
| | #4 |
| Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
| Kamikaze, do you mean in wheel speed or torque byt changin to 35t? Sorry for the noob? |
| | #5 |
| Both |
| | #6 |
| I'm a little confused. I thought with higher turns you get more torque and less wheel speed. So I would want more turns, but, kamikaze says less? |
| | #7 |
| RCC Addict Join Date: May 2006 Location: China Grove, NC
| hey More turns means less power over all. (lower amp draw, due to higher internal resistance) A higher turn motor does run happier in the low rpm range, but I have found anything over a 55t is fairly useless on a super unless you run 9.6v (8cells) or more. If you have a rooster, I think you can run dual 35s, if you have a rooster crawler you can only run dual 55s. Going to a 7 cell will always help. Last edited by renoirbud; 04-22-2008 at 06:56 AM. |
| | #8 |
| The higher turn motors do produce more wheelspeed but torque goes up as well. This is what i have learned from the switch that i made. My first setup was 8t pinions,55t motors,and 7 cell NIMH knuckle packs. I never broke the stock gears with that setup.(i run CVD's so axles were not a issue). New setup. 7tooth pinions,45tmotors,and a 3 cell lipo. I have more wheelspeed than before and the stock clod gear set can be broke on demand.You get the truck in a bind and give it the throttle and something is going to move or break. I now have a set of 6tooth pinions,35t motors,and allum. gearsets on the way. |
| | #9 |
| I have a pair of 27 turn motors (not sure on brand) should I try these? I thought since I was happy with the wheelspeed and torque with stock sized tires I just needed some more juice with the taller 40s but maybe a motor change is needed? |
| | #10 | |
| Pebble Pounder Join Date: Dec 2007 Location: Canby, Oregon
So all this time I thought "higher turn=more torque" I was wrong? What would be good for a NN chassis running raptor2 axles BTW i have 2:1 units and a MM with 3 cell lipo but have been told it can handle 4...hmmm | |
| | #11 |
| Rock Stacker Join Date: Dec 2007 Location: B.C.canada
| i got 40 series mudslingers with 2 55turn integys,8 tooth pinions,9000mha 7cell,it is awsome,except for my rooster crawler esc from novak,its junk |
| | #12 |
| Rock Stacker Join Date: Jan 2006 Location: Willamette Valley
| Questions answered thanks! But what brushless motor/ and pinion combo would work similar to this? -----New setup. 7tooth pinions,45tmotors,and a 3 cell lipo--------- Last edited by gta3wheeler; 04-23-2008 at 02:28 AM. |
| Thread Tools | |
| Display Modes | |
