Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: Sharper clod turning
Old 04-27-2008, 09:26 PM   #1
Default Sharper clod turning
How can I make the turning radius sharper on the clod axles? Do I just trim the bump stops?
CrawlinJunky is offline   Reply With Quote
Old 04-27-2008, 11:54 PM   #2
TCS/Holmes Hobbies
SVEN's Avatar
Yes, trimming the stops will gain you a lot more steering. After that, if you still want more steering you can get CVD's, shave the axle tubes, and get aftermarket knuckles that provide more clearance.
SVEN is offline   Reply With Quote
Old 04-28-2008, 12:32 AM   #3
how much more can I get without going to cvd's? I trimmed my bump stops and it looks like I can start shaving on the knuckles to get more but I haven't done it yet because I wasn't sure...anyone tried this?
jlmotox is offline   Reply With Quote
Old 04-28-2008, 03:45 AM   #4
flip your hubs to put the draglink behind the axle helps alot or run a smaller pinion in the rear and it will turn better
chafee is offline   Reply With Quote
Old 04-28-2008, 08:52 AM   #5
666
666's Avatar
You can shave the knuckles for more, grind the insides of the drive cups all for more steering. Just look at all the places it hits as you cycle the steering and grind away!!
666 is online now   Reply With Quote
Old 04-28-2008, 07:03 PM   #6
Exclamation Knuckles
How do I shave the knuckles?
Old 04-28-2008, 07:12 PM   #7
Instal front dig.
carbonuts is offline   Reply With Quote
Old 04-29-2008, 06:34 PM   #8
Do you know an easy way to install front dig? I'm sorta a newbie.
Old 04-30-2008, 08:55 AM   #9
you're going to need a micro switch and a servo....there's a write up of the Clod dig mod in here somewhere.
try searching the key word dig in this forum
ussprinceton2004 is online now   Reply With Quote
Old 04-30-2008, 12:30 PM   #10
Choppin' it up.
Szczerba's Avatar
On the "Tech" page on the main www.rccrawler.com. Various setups tested.
http://www.rccrawler.com/maxsteering.html
Szczerba is online now   Reply With Quote
Old 04-30-2008, 07:31 PM   #11
K Thanks
