05-27-2008, 03:32 PM | #1 |
Newbie Join Date: Jan 2007 Location: Florida
| Squatty Clod
Long time reader, first time poster. I have a CPE Sniper (old style) Clod used mostly for bashing and a little crawling. I have locked rear diff, open front diff, TTR Wheel wideners, stock tires and wheels and stock body. Super Duty XR esc, with 15T Venom Fireballs and 9T pinions. Its a lot of fun to drive with one battery pack, but 2 battery packs is insane. The only problem i have is my shocks. With 2 battery packs, the truck squats on take off an never recovers. It also bottoms out on every minor jump. I am using the stock E-Maxx oil shocks with the red springs. Would the blue springs (rated at 8.3 lbs) be enough to handle the truck and the 2 battery packs or could someone advise a totally different shock set-up. I was looking at the Integy shocks for the LST (MSR6 I believe), but have not heard anything good about Integy products.
05-27-2008, 04:12 PM | #2 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
Firmer springs are definately going to help. Maybe try standing them up a little more vertical?
05-28-2008, 07:18 AM | #3 |
that would definitely be the cheapest route
06-06-2008, 07:04 PM | #4 |
Rock Stacker Join Date: Aug 2007 Location: Sellersville
I can't comment on the dual battery pack part, but my CPE Evolution stays pretty stable with stock Associated MGT shocks. They have faux resevoirs and only squat a bit on takeoff but come back pretty well after a few feet.
06-06-2008, 07:29 PM | #5 |
Pebble Pounder Join Date: Dec 2007 Location: Canby, Oregon
Throw some shims on the springs for a little more pre-load. That would be the cheapest way to go for firmer springs. If you still bottom out try some thicker oil. |
06-06-2008, 08:38 PM | #6 |
Pebble Pounder Join Date: Mar 2008 Location: yes
Have you made sure the shocks aren't sticking and need a rebuild? If not then spring up and thicken the oil.
06-16-2008, 08:58 AM | #7 |
The truck does great with one battery pack, but 2 makes it squat and it never comes back up until i let off the throttle. I will try some stiffer springs and thicker oil and see what that does. Thanks for the replies.
