07-14-2008, 01:58 AM | #1 |
Rock Crawler Join Date: May 2008 Location: The Beautiful South
| 20mm wheel adapter for the clod???
I couldn't find any. Do you know of any?
07-15-2008, 11:22 AM | #2 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
The Losi LST2 uses 20mm hexes. The LST2 has 8mm CVD's which is the same size as TTR CVD's. So if you are using TTR CVD's or TTR Straight axles (TTR = Thunder Tech Racing), they will fit. You may have to slightly modify the hex depending on drive pin location and knuckle clearance. If you are using stock clod axles though, I am unaware of any company making an adapter to 20mm. 23mm is more popular and I have used several different brands of 23mm hexes for the Losi LST2 on TTR CVD's for the Tamiya Clod. Some needed modifications while others bolted right up. |
07-15-2008, 09:43 PM | #3 |
thanks, but I have a slew of 14, 17 and 20mm wheels at home right now and I want to use them. I just bought some 17mm adapters.
