08-05-2004, 09:24 PM | #1 |
Newbie Join Date: May 2004
| motors
how come u guys say that one motor is for forward and one is for backwards if thats true how do you make them turn the same way |
08-05-2004, 09:45 PM | #2 |
Quarry Creeper Join Date: May 2004 Location: Boobslando, florida
| Re: motors
lol um flip your wires over.....I had the same problem but i quickly fixed it by just flipping tthe rear wire oppisite of the front |
08-05-2004, 09:45 PM | #3 |
Quarry Creeper Join Date: Jul 2004 Location: 808
| Re: motors
Some guys reverse the timeing, some guys just wire one motor backwards. I have a reverse rotation motor in my truck. But when I get around to picking up my new motors Ill just wire one backwards.
08-06-2004, 12:28 AM | #4 |
| Re: motors
With stock motors (or any motor with zero degrees timing) you can just hook the wires up opposite on the rear motor and then the axles will spin the same direction. For motors with fixed timing you wire them up the same (+ wire to + terminal, -wire to - terminal) front and rear but the rear motor must be a reverse rotation. The front and rear gearcase of a clod are exactly the same but the one in the rear of the truck is turned around so it tries to drive the opposite direction of the front unless the rear motor is spinning opposite. Thats where the term "reverse rotation" comes from. |
08-06-2004, 08:29 AM | #5 |
| Re: motors
so it will not be 4wd
