Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Integy Clod axle with spool or diff
Old 08-20-2008, 10:38 AM   #1
Default Integy Clod axle with spool or diff
Hello all, i'm new here and new to Crawling and have a question i can't find on the Interwebz ^^
The question is about the Integy alloy Clod axles. One axle comes with a 'spool' and the other one with a 'diff'. What's the difference about these two? And witch one must i take? The 'spool' axle is 30USD more expensive then the other one whay is that?
I hope you guys can help me!
Here are the links to the Clod axles
http://www.integy.com/cgi-bin/webc.cgi/st_prod.html?p_prodid=5033&p_catid=
http://www.integy.com/cgi-bin/webc.cgi/st_prod.html?p_prodid=5034&p_catid=
Dutch Crawler is offline   Reply With Quote
Old 08-20-2008, 11:10 AM   #2
You'll need both. One has a solid differential, for the rear, the other have a limted slip (adjustable) for the front wheels.
Renslipevol is offline   Reply With Quote
Old 08-20-2008, 11:29 AM   #3
Spool front and Rear is what you need.
Old 08-20-2008, 11:36 AM   #4
you do not want a diff on any kind of crawler
you will need spools front and rear.
sloppy is offline   Reply With Quote
Old 08-20-2008, 02:42 PM   #5
Ok tnx guys!
Now i must find a nice chassis or build it my self :-P
Old 08-20-2008, 03:56 PM   #6
I don't know about that. The integy adjustable diff is pretty nice. The tension on the slipper can be set to wherever you want it to slip at. I really like them. It's all a matter of taste.
