09-04-2008, 11:26 PM | #1 |
Newbie Join Date: Aug 2008 Location: snohomish
| rockbull chassis?
I have a rockbull chassis and would like to hear some feedback if others have this chassis and how happy they are with it maybe some pictures of how they have them set up
09-06-2008, 10:41 PM | #2 |
Newbie Join Date: Jul 2008 Location: Seattle
I am in the process of finishing my Rockbull kit. I will try to post some pictures soon. Did you get the chassis or the whole kit? Use locktite everywhere! Get some wheel extensions from RC4WD my tires rub on my lower links bad. I am fighting "clodstall" right now but am going to try smaller pinion in rear axle along with wiring motors in parallel and uping my voltage from a 7 cell nihm to a 3c lipo. I hope this combination helps, the motors stalling sucks. Good luck on your build I will try and post some pictures of my truck when I finally get it "right".
09-07-2008, 06:44 PM | #3 |
Rock Crawler Join Date: May 2007 Location: Valdosta
I am still working on mine. I had it built up once but I didn't like the stock gearing so I changed some things around and am working on some gear reduction units. Here's a couple pics. |
09-07-2008, 10:13 PM | #4 |
Rock Stacker Join Date: Aug 2008 Location: Austin
Nice! What wheels are those?
09-07-2008, 10:50 PM | #5 |
The wheels are RC4WD Rockstar 40 series beadlocks. They are very cool and extra beefy. I'm still trying to dial my truck in but its half the fun messing with it.
09-08-2008, 04:36 PM | #6 |
09-08-2008, 07:20 PM | #7 |
I bought the rockbull 3 chassis with the bent links and have already broke one of the lower links not super happy with chassis so far
09-08-2008, 10:59 PM | #8 |
The bent links don't seem as strong as the straight links and it is a heavy truck. I'v only had mine out a few times but my bent links are holding up so far. Whats your electrical setup? Are you having clodstall issues? I just ordered up so more goodies to help try and get it dialed in. Good luck.
09-09-2008, 12:38 AM | #9 |
What other goodies did you get? |
09-09-2008, 04:41 AM | #10 | |
I have a question for you on how you mounted the bent links. Did you mount the shock to the pre-bent part of the link, or after the bend? Here's a picture of how I mounted mine, it seems pretty strong this way and it doesn't create a rediculouse ride height. I also put a hair elastic thing that most people use to make scale bungee cords around the shock mounts to get rid of the little bit of slop you get with bent links. | |
09-09-2008, 06:53 PM | #11 |
on the rockbull III chassis it has the rocket bent lower links I had them mounted two ways actually the first way I had them mounted like in the pictures sat way too high and had no give in the suspension so I changed them around and it lowered the truck which was much better until the one link broke still doesnt seem like a real capable chassis as far as electronics go I have rooster crawler 55T integey motors and futaba high torque servos locked front and rear If I had to do it over again Id go with a stick or hustler chassis |
09-09-2008, 06:59 PM | #12 | |
