10-05-2008, 09:13 AM | #1 |
RCC Addict Join Date: Jun 2006 Location: IN THE PIT !!
| tha DmG's -DCS/VP something NEW form the DmG now in testing !! the DmG's - DCS/VP super class alum TVP TUBER chassis !!! keep watching for up dates !! |
10-05-2008, 09:19 AM | #2 |
Watching!! BTW, I like mine better!! |
10-05-2008, 12:18 PM | #3 |
Quarry Creeper Join Date: Nov 2007 Location: Cincinnati
what's up with all the abbreviations? what's a DCS, a VP or a TVP for that matter? on another note, nice chassis.
10-05-2008, 12:58 PM | #4 |
TVP=Twin Vertical Plate DC=not sure, but that is what most of his projects are called and the S=super. |
10-05-2008, 01:36 PM | #5 |
RCC Addict Join Date: Jun 2004 Location: Little Rock, AR
Me likey! You bringing any to Disney?
10-05-2008, 04:20 PM | #6 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
10-06-2008, 09:04 AM | #7 |
10-06-2008, 11:36 AM | #8 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
10-06-2008, 09:11 PM | #9 |
RCC Addict Join Date: May 2008 Location: On the rocks
Looking good Jerry. DCS = Death Comp Super Im working on your original DCS build. I should have a build thread in this section anyday. Still waiting on BTA, and counter gears.... |
10-06-2008, 11:02 PM | #10 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
if i can find room for it in the limited suitecase space i have. Unfortunately I havent built it up yet since the NN was done already for crawlapalooza but it will get built when i get back Last edited by yukon635; 10-06-2008 at 11:18 PM. |
10-07-2008, 08:30 PM | #11 |
10-07-2008, 09:01 PM | #12 |
Quarry Creeper Join Date: Feb 2007 Location: Tokyo, Japan
...another one to watch Great stuff |
11-05-2008, 08:12 AM | #13 |
Well I got all the material/parts to complete this build. Thanks again to MThead for cutting me a killer custom skid Here are some specs about the frame (made by ZORLAC/DMG): - its made with 1/16 6061 T6 side plates & 3/16 & 1/4 rod - all alum. with a delrin skid - the over all length is 22 1/4" - height is just under 4" - width is 3" - side panels are 3" tall. around 300 grams total , SUPER lightweight !! The original skid opted for the links to be mounted on the outside of the side plates. I decided to inboard them so that there is less to get hung on and also to try and reduce axle steer Last edited by yukon635; 11-05-2008 at 08:37 AM. |
11-05-2008, 08:26 AM | #14 |
Quarry Creeper Join Date: Sep 2008 Location: sterling VA
very nice, i want one, are u taking orders yet? lol
11-05-2008, 09:49 AM | #15 |
| DCS/VP in testing YUKON is testing this prototype to see how everything mounts up & how it works out. when i get all the info on it & it checks out ,i will be having DNA cut the side plates & start taking per orders !! thanks the DmG |
11-05-2008, 10:12 AM | #16 |
Lower links are 1/2" delrin rod (mcmaster.com) with revo rod ends These links are super easy to make, cheap, and slide over the rocks alot better than aluminum Tapped the ends, used some 4x25mm set screw, and tapered the ends off |
11-06-2008, 11:41 PM | #17 |
It's finally a roller :-P As of now, it is sitting at 17.25" WB and 4.5" belly clearance I should have it running by this weekend and get some run time on it Here you can see the space available inside of the chassis. That is an Elite 3s 4800 mah lipo sitting in there |
11-07-2008, 01:25 AM | #18 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
Looks like it will work there,Good job yukon I may get me some of that delrin rod.How thick is the skid plate? |
11-07-2008, 07:51 AM | #19 |
11-07-2008, 11:08 AM | #20 |
| nice work , yukon - looks good the DmG |
