10-07-2008, 05:36 PM | #1 |
Pebble Pounder Join Date: Jun 2006 Location: Saint John, NB Canada
| Very strange motor/axle issue
This might be normal, not sure. My setup consist of a Traxxas EVX2, new Integy 35T motors, and 8t pinions. I installed my motors and the truck drives fine, I turn the truck off and dissconnect the battery, and if I grab the front wheel and turn it by hand there is a fair amount of resistance, if I turn it fast enough the rear wheels will start to turn with the front I was surprised because of course the Clods axles are independent of one another. Then if I dissconnect one of the motor wires there is way less resistance when I turn the wheel and the rear wheels will not turn with the fronts anymore. Is this normal with an EVX2 esc? |
10-07-2008, 07:36 PM | #2 |
Quarry Creeper Join Date: Jun 2007 Location: Calgary, Alberta
I think what you are seeing is a generator when you turn the wheels. Its inducing a voltage into the other motor which is causing it to turn.
10-07-2008, 07:48 PM | #3 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
When you turn the one set of tires you are creating a generator effect that is feeding into the other motor causing it to turn. It is completely normal. |
10-07-2008, 08:03 PM | #4 |
Quarry Creeper Join Date: Nov 2007 Location: Cincinnati
10-08-2008, 04:54 PM | #5 |
Rock Crawler Join Date: Aug 2008 Location: Tucson
It is pretty weird/cool the first time you see it. I wonder if this has something to do with clod stall? Has anyone tried using a power capacitator on the rear motor? That way when the front spins fast and rear starts to stall the power capacitator would release the stored charge and give a little bump in voltage to the rear motor. Then again, if you mention clod stall the first answer youll get is, buy a 4 ch stick radio.
