Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: I enjoy 2.2clod!
Old 10-22-2008, 09:09 PM   #1
Smile I enjoy 2.2clod!
Nice to meet you.:-P
It is writing from Japan.
I will refer to the idea of everybody.
clod axles
HR axletubes, Knuckles,
handmade BTA,
TTR CVD's, Straights,
TAMIYA Modefaid12mmHex's,
7Tpinions
mamba25 & enRoute28long-1300, 2set
Hyperion servo, DX6i
TAMIYA avante2 rearwheels, LOSI claws,
himo is offline   Reply With Quote
Old 10-22-2008, 09:21 PM   #2
Good job on those axles, im sure its better clearance than stock, did u burn those?
bullet1231 is offline   Reply With Quote
Old 10-23-2008, 01:28 AM   #3
Photo miremashita
OIRA ha Comment de Debut desu. www
Korega souryou $49.56 no Parts desune. "lixxid" (-人-) namunamu...
Sorenishitemo bullhead mo zuibun AROku narimashitane.w
TOZAN tanoshimidesu.^^
Kuri is offline   Reply With Quote
Old 10-23-2008, 08:47 AM   #4
thanks:-P
sorry,Because English is unskilled
Though it doesn't understand whether you can answer neatly
The projection of Ledge is cut down.
The tape is pasted.
Old 10-23-2008, 08:49 AM   #5
Originally Posted by Kuri View Post
Photo miremashita
otagai eigono bennkyou wo sinakya desune www
TOZAN yorosiku desu
Old 10-23-2008, 08:55 AM   #6
~THE SCALE SHOP~
are dark impact wheels 2.2 ?
STANG KILLA SS is offline   Reply With Quote
Old 10-23-2008, 09:39 AM   #7
I compared it with HPI 2.2wheels.
It might be slightly large.
sorry,I cannot judge whether to pass the rule.
Old 12-02-2008, 06:16 AM   #8
Default more narrow
Cut off
HEXhole is made
Aluminum spacer
Completion!
Old 12-02-2008, 07:00 AM   #9
Looks great! I did something similar with my TTR CVDs! They work quite narrow!
Nice crawling spots, BTW.
JeremyH is offline   Reply With Quote
Old 12-02-2008, 07:26 AM   #10
Thank you JeremyH!
This method, the choice of a wheel increases.
But,durability is [ one ] anxious about me.
Become single bearing.
I run for the time being!
Old 12-03-2008, 07:09 AM   #11
Are those the JP small C tubes and knuckles? If so, then you should be able to still fit both bearings inside. You can see how I narrowed the stance of my 2.2 clod running small C tubes, JP knuckles and TTRs on page 3 of my build thread:
New Build
I am running different hexes on mine (14mm losi), but the idea is still the same.
Old 12-03-2008, 07:37 AM   #12
Thank you JeremyH!
I was allowed to see the thread before! Your rig is wonderful!
Although I also tried the same method as you at first,
Since I was poor at English, acquisition of the wheel was not completed.
And I tried how to be different.
I will refer to your thread in the future!
New Build
Old 12-03-2008, 07:54 AM   #13
Sounds good!
Good luck with your build!
