Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: which way?
Old 08-18-2005, 03:02 AM   #1
Default which way?
Im not sure which way to go with my next mod, should i go with the lathe motors to get more pull or should i go with 8 tooth pinions and the adjustment plates and stock motors, im using a tekin titan so the motor turns shouldnt be a problem.
Oh im also new here been looking around for a couple of weeks but only just joined
clod pete is offline   Reply With Quote
Old 08-18-2005, 03:32 AM   #2
get some laith motors. then get the pinions . what size of pinions are you running right now?
rockraper is offline   Reply With Quote
Old 08-18-2005, 04:06 AM   #3
just the standard clod stuff with locked diffs and modified suspension
Old 08-18-2005, 12:17 PM   #4
TEAM MODERATOR
EeePee's Avatar
Lathe motors definately. You may not want the smaller pinions, and wouldn't need the adjustable motor mounts. Or, you can go down to 10 teeth pinions without the adjustable mounts.
EeePee is online now   Reply With Quote
Old 08-18-2005, 01:34 PM   #5
How much contact surface do the teeth have without adjustable mounts?
And yes, buy the lathes 1st.
Trailerguy is offline   Reply With Quote
