Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: Homebuilt Crawler
Old 08-18-2005, 10:28 PM   #1
Default Homebuilt Crawler
http://www.boomspeed.com/repobud/3.JPG
http://www.boomspeed.com/repobud/2.JPG
http://www.boomspeed.com/repobud/1.JPG
http://www.boomspeed.com/repobud/4.JPG
Homemade chassis and links,super rooster,integy lathes, clod mod motor mounts, 9t pinions, locked gearboxes with full bearings, behind the axle steering, 4 inch powerline threaded alu. shocks and 3/4 inch wheel wideners. hobbico high torque metal gear bb servo. 16.5 inch wheel base.
what do you think??
REPOBUD is offline   Reply With Quote
Old 08-18-2005, 10:35 PM   #2
have you had any problems with hitting your links? if u are, someone gave me advice which helped my clearance alot ....if you move your link to the top of the C hub you will gain like 1 inch clearance without losing your wheelbase
dansmith is offline   Reply With Quote
Old 08-18-2005, 10:35 PM   #3
looks awsome by the way
Old 08-18-2005, 11:02 PM   #4
the cog looks very low. can you stand it up on its side without it falling over?
ILoveRCRockCrawlin is offline   Reply With Quote
Old 08-19-2005, 02:45 AM   #5
v33
would love to see a side view, full horrizontal shot and not angled like you did with pic (4.JPG). whats going on with the battery placement?
if you cut the wheels, i bet you wouldnt need wideners ... well maybe 1/4 inch would be enough.
i really love the low profile on that truck ... im also trying to do the same on mine, except im looking for a way of not cutting the lexan drastically.
v33 is offline   Reply With Quote
Old 08-19-2005, 09:32 AM   #6
i spent a long time playing w/ diffrent link and shock mount locations. this setup seems to work the best for this chassis.
yes i can stand it on its side without falling over.
i will try to get somemore pics tonight (my wife has the digi cam out w/ her)
thanks for all the replys glad you liked it!!
I was going to strap the battery under the chassis, but to get it running i rubberbanded it to the front lower links. it worked out well so i left it . I think it also helps w/ traction haveing the weight on the front wheels.
Old 08-21-2005, 06:58 PM   #7
Ttt
