Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Can't keep servo's up to my Hustler
Old 11-17-2008, 02:09 AM   #1
Default Can't keep servo's up to my Hustler
Hi all
As the title says I'm having trouble with burning up servo's on my Hustler.
As far as I know i am doing things right but help would be appreciated.
I have done 2 Hitec 5995's, they were supposed to be the best at the time.
The end points are set and im running CC BEC set at 6v. Are these servo's just not up to the job? or should I go bigger?
Aza
aza280 is offline   Reply With Quote
Old 11-17-2008, 06:35 AM   #2
check your wiring, the CC bec is most likely the culprit. those servos are built like tanks, i know cause i have 4 of them. make sure they are wired right if not they will burn ANY servo you throw in there.
bullet1231 is offline   Reply With Quote
Old 11-18-2008, 12:08 AM   #3
This is a very rough diagram of the wiring is there anything wrong with it?.
