Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: Cobra Clod (going for pretty this time)
Old 08-23-2005, 12:00 PM   #1
Default Cobra Clod (going for pretty this time)
Got bored again.
Have a few gearboxes lying around, so had a bit of an Autocad play
Had the plates made at www.fibre-lyte.co.uk, mental sevice, ordered them on Friday, arrived the following Tuesday
For the failed submissions, click HERE
TWINSET is offline   Reply With Quote
Old 08-23-2005, 02:03 PM   #2
Powered by Awesome
TwistedXT's Avatar
How and the Hello did you cut that out? looks pretty cool so far
TwistedXT is online now   Reply With Quote
Old 08-23-2005, 02:09 PM   #3
Have a look at the fibre-lyte site, they do custom work, all I did was draw it and pay for it
Old 08-23-2005, 03:05 PM   #4
perfictsib's Avatar
i know this aint small scale forum but hows belt buckle crawler doing
perfictsib is offline   Reply With Quote
Old 08-23-2005, 04:20 PM   #5
How much was it for them to make it and then how much was shipping from the UK to the US?
Plays_with_Toys is offline   Reply With Quote
Old 08-24-2005, 11:36 AM   #6
Plays....
There were around $42 each including UK taxes, postage to the US should be very very little, plus $8 for fast, insured service.
As for the belt buckle, it's kinda on hold, for some reason it keeps burning ESC's so until I rustle up some £££ for a good one, it's an ornament
I think the pinion was rubbing inside the gearbox, couldn't find friction anywhere else
Last big ESC catastrophe can be viewed HERE
Old 08-24-2005, 02:13 PM   #7
EDIT: Oh 42 dollars! WOW! Thats a good deal! I know for a carbon fiber set of my chassis plates it was just over $100 for the set, and it doesn't have that kind of extensive inner work.
Old 08-26-2005, 11:37 AM   #8
That's $42 each plate.
If you have any drawings or DXF files, I'd be happy to get them to quote
Old 08-26-2005, 12:22 PM   #9
RIP Buster
badger's Avatar
Originally Posted by TWINSET
That setup won't work because the botton of the shocks are not attached to anything.
Just in case you did not notice yourslef.
And how did you get the upper links to attach to the tires?
badger is offline   Reply With Quote
Old 08-26-2005, 12:26 PM   #10
Everything else is made out of trasparent titanium, clear anodiesd.
Jeez, you aint still using plastic are ya?
Old 08-26-2005, 02:55 PM   #11
were do you get the trasparent titanium?? I had some and no I can't find it??
TheEvilKanoofy is offline   Reply With Quote
Old 08-26-2005, 04:41 PM   #12
Don't worry, I am sure one day you'll be walking and BAM! it'll find you
Old 08-26-2005, 04:53 PM   #13
Did you say pretty?
What next cute?
FrankyRizzo is offline   Reply With Quote
Old 08-27-2005, 01:22 AM   #14
v33
id rather watch cartoon channel that read the funnies here
get back to topic!
v33 is offline   Reply With Quote
Old 08-27-2005, 06:33 AM   #15
Cool timing, postman just dropped this lot off;
From bottom row;
Radio tray
Battery tray
Servo Mounts
Brace shock mounts
Battery Tray
Radio Tray
Shock Mounts (for the bottom chassis)
Aluminium Cobra and an Iron Cross for a mate
Fancied building a fast one too this time ;)
Old 08-27-2005, 03:13 PM   #16
9 hours later..................................
Old 08-27-2005, 05:30 PM   #17
wow very cool! I would say you should mount the bottom links higher on the axle and the top links lower on the chassis and then you would get more clearance. Thats the only thing i can see that i don't really care too much for. Also Is this going to be a shelf queen?
I got a kick out of that video!
RCMFMaxxMan is offline   Reply With Quote
Old 08-28-2005, 11:40 AM   #18
That wasn't the intention, out of interest why do you ask?
I've only really built one shelfer, and that was Willy Rash, mainly because it's got a hard shell with a real nice paintjob (that and the fact I hate the torque twist)
Old 08-28-2005, 11:54 AM   #19
Old 08-29-2005, 03:41 PM   #20
I was just kind of wondering because for one you called it "pretty" and for two the links don't seem to be in the best spot because most clods these days are mounting the top and bottom links closer together at the chassis and the bottom links higher on the axles. So anyways thats the reasons behind my madness
