Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: do you need axle stiffeners?
Old 12-27-2008, 07:32 PM   #1
Default do you need axle stiffeners?
when running aluminum axle shafts do you still need to use the diagonal axle stiffeners? is there any strength gain or loss by or by not using them?
4ONDFLR is offline   Reply With Quote
Old 12-27-2008, 08:21 PM   #2
If you run the aluminum axle tubes, but still use the stock plastic case, leaving off the angled braces can transfer a lot of stress through the 4 bolts mounting the tube to the case.
CPE MT is offline   Reply With Quote
Old 12-28-2008, 07:53 AM   #3
I havent had any problems with my setup (of course, I am only running 2.2's):
JeremyH is offline   Reply With Quote
Old 12-28-2008, 01:22 PM   #4
I'd still run the braces, or brace. (depends if you have a servo mount that replaces the one brace) You could possibily break the plastic gearcase housing, but I imagine it would hold up reasonably well, as long is didn't get knocked around really hard, like taking a tumble down a hill. I have full metal cases and I still run the braces. Sometimes they are handy for servo mounts and electronic/battery mounting plates.
Espeefan is offline   Reply With Quote
Old 01-16-2009, 10:38 PM   #5
Agree. I would run them to be safe, otherwise you might be replacing the center pumpkin
Pzl1nz is offline   Reply With Quote
