| | #1 |
| Newbie Join Date: Jul 2005 Location: Charlotte
| Hey i just blew up my clod hub bearing. I was wondering where i might pick one or more of these up. Just to be sure this is the bearing at the very end of the hub/knuckle that sits under the snap ring which i also need. thanks |
| Sponsored Links | |
| | #2 |
| also what size is that bearing? |
| | #3 |
| Quarry Creeper Join Date: Aug 2005 Location: Asia
| the bearing for the axles and knuckles are 6x12mm. the clod uses 2 types of bearings and these are the 6x12mm, which you need, and the 5x8mm which is used by the gears inside the gearbox. are the snap rings the same as the e-rings? these come with 'Screw Bag D' for the clod. try ordering them from clodparts.com or maybe your lhs. hth |
| Thread Tools | |
| Display Modes | |
