01-11-2009, 08:26 AM | #1 |
RCC Addict Join Date: Jan 2008 Location: www.rccrawler.com
| Is It Just The Thundertech BTA That Sucks ???I've Never Tried Others...
Hours of tuning this thing and I'm still wondering ...their other products are good but WTF is it with this piece of shit??? I'm getting rid of it A.S.A.P Can anyone recommend other BTAs that actually work properly???? |
01-11-2009, 08:31 AM | #2 |
RCC Addict Join Date: Jul 2006 Location: barstow
your not the only one i never could get mine to work either it would hit the motor and i had a short endbell. along with the servo not really being secured well and the linkage was horrible
01-11-2009, 08:34 AM | #3 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
I've heard of the Thundertech carbon tie-rod snapping, but not that it didn't actually fit. May depend on what chassis you're using if your issue is with hitting one of the links. We have a SS BTA kit that keeps all the axle bracing, and there's a Hand Bros kit available that removes the axle brace. |
01-11-2009, 08:47 AM | #4 |
#1 I worked out the motor thing by grinding 2mm off on the motor and reduced the servo horn by 7mm #2 The steering angle was almost non existent... #3 Played around with the tie rod length and on the next test run the aluminum link was bent (it woulda snapped 4 sure if it were the CF version) #4 My last try is reversing the link and using a much longer tie rod to reach the connection I had to grind the bottom of the gear case there about 1mm too ...lets see if it holds up |
01-11-2009, 08:59 AM | #5 | |
And Ive heard a few guys say that they have spent hours on modding the thing just to squeeze a couple more milliliters of steer out of it ... So all I am asking is how do for example your BTA kit or Hand Brothers kit do as far as getting a decent amount of steer compared to this one... | |
01-11-2009, 01:39 PM | #6 |
Quarry Creeper Join Date: Sep 2008 Location: sterling VA
hands bros BTA kit, best for clods, hands down.
01-11-2009, 03:57 PM | #7 |
Quarry Creeper Join Date: Apr 2008 Location: Fondy, WI
01-11-2009, 04:09 PM | #8 |
You may get away with that kit for a crawler, but you'll break stock axle tubes left and right if used on a basher/racer. Removing the axle brace like that kit does would be fine if you're running aluminum tubes though. |
01-11-2009, 04:21 PM | #9 |
I never had any luck with it, the carbon fiber piece wore out, so I made a aluminum one, the mount broke, got a new one, broke again, threw it in a box, who needs BTA. And don't run w/out braces unless you have aluminum tubes. |
01-11-2009, 06:25 PM | #10 |
Rock Crawler Join Date: Feb 2008 Location: CHESAPEAKE, Va
i run the CPE one with no problems at all! plus it give you 2 diffrent ways to mount the servo |
01-12-2009, 01:07 PM | #11 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
I have had two on my CNNN and my Hustler and now have Hands bros and no question the hands bros takes it. I got the Thundertech to work but was always breaking things bending servo horns etc. And when I was first staring out I got Thundertech lockers and they lasted all of 45 sec before striping....
01-12-2009, 02:22 PM | #12 |
Moderator Join Date: Apr 2004 Location: In my head
I ran the Thundertech steering on my Clod that I won Nationals with in 07. Overall I'd give it an okay rating. I got it set-up with out any major headaches. I split the CF tierod but that was my fault. It was a 13+ pound truck which the front axle probably weights 6+ pounds and I was jumping a 4"x4" popping the front end off the ground. Funny part is I super glued it back together and it never split again. My main issues with it was steering angle and it didn't seem efficient like too must friction. I've wanted to run the Hands Bro but .... never have yet. I was a little scared about losing the brace. |
01-22-2009, 05:17 PM | #13 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
01-23-2009, 04:43 PM | #14 |
Rock Stacker Join Date: Dec 2008 Location: Ogden
I just put the TTR BTA on my truck. My tie rod is aluminum, i don't know if that is weird or not. Mine seems to move the tires from side to side and put them in full lock positions too. The only problems that i have had with it is the screws backing out where the tie rod meets the knuckles. But it seems to be better now since i put some washers in between the nuckle and the tie rod.
01-25-2009, 11:51 PM | #15 |
Rock Stacker Join Date: Jul 2004
| Home built
I built my own bta kit from aluminum angle for the servo mount and after alot of trial and error I noticed that the closer I got the tirod to the nuckle the easyer time the servo had and the more turning I got out of it also want to keep the 2 tirods parallel. I know this is different than the thnder tech set up but this might help. I know drilling the stock nuckles isnt anyway to make the most durable mod ....(got aluminum on order)....hope this gives ideas Last edited by gac1983; 01-25-2009 at 11:53 PM. Reason: mis spelled word |
