| | #1 |
| RCC Addict Join Date: Jun 2004 Location: SERCRC
| I noticed something when fitting 2.2" wheels designed for the Traxxas Rustler or Stampede onto my clod. The 12mm brass hex has a 'lip' on it that keeps the hex from completely seating into the wheel. Another problem was that the wheel nut didn't tighten down onto the wheel enough to keep it from wiggling around a little. Add these two problems together and what happens? Yep, rounded two wheels out in the first 10 minutes. What I did to remedy this situation: First I filed down the 'lip' on the hex to allow it to fully seat into the wheel. Pics are blurry so I drew a picture.... Before: ![]() After: ![]() With the 'lip' filed down the hex fully engaged into the wheel: ![]() Next to deal with the wheel nut not completely tightening down on the wheel. I found that some of the left over bushings from my TXT kit were a perfect press fit into the front of the 'Pede rear wheels that I run. I think these are the 1150 size, can be bought at Tower. http://www2.towerhobbies.com/cgi-bin...?&I=LXSK70&P=Z ![]() Now with the wheels tightened down nice and snug and the hex fully engaged into the wheel rounded hexes are a thing of the past. ;) I've been hammering on this set-up for a couple of weeks now with no problems. |
| Sponsored Links | |
| | #2 |
| I wanna be Dave ![]() Join Date: Mar 2005 Location: Hiding from Goodall
| you only ripped 2 hexes? crap my first run with my 2.2 clod I shot all 4. The plastic bushings that come with tamiya kits also work really well for spacers for the wheel nut |
| | #3 | |
| | #4 |
| Quarry Creeper Join Date: Aug 2005 Location: Asia
| thanks for the heads up on this ... it will come in handy. |
| | #5 |
| Quarry Creeper Join Date: Oct 2005 Location: SoCal
| Great Info Wish I seen this sooner Stripped out a few hexes myself this past month |
| | #6 |
| Almost a year later, I'm still running that same set of wheels...... they're still holding up. ;) |
| | #7 |
| Quarry Creeper Join Date: Jan 2006 Location: Jonesboro, TN
| Thats the same thing I done except I used washers on the outside instead of bushings. I will see what kind of bushings I have lying around though. |
| | #8 |
| ... Join Date: Sep 2005 Location: USA
| Thanks, That was some need to now info. I'll pass it on. |
| | #9 |
| Pebble Pounder Join Date: Jul 2006 Location: Out of my mind!!
| Yeah, thanks 4 letting us know about that. I was fixing 2 run my clod like that, but not now. what'd you use to file them down? |
| | #10 |
| Quarry Creeper Join Date: Jun 2006 Location: boondocks
| dremel/grinder works best id assume |
| | #11 |
| Rock Crawler Join Date: Feb 2006 Location: Clovis, NM
| What pede wheels you using rear electric or gas? Or does it matter? Will HPI wheels work too? |
| | #12 |
| I use wheels designed for the REAR of the electric Stampede/Rustler. The rear 'pede wheels have more backspacing than the fronts, making them a better choice for Clod or TXT axles. With rear 'pede wheels my 2.2" Clod has a total width of 11.5". |
| Thread Tools | |
| Display Modes | |
