| | #1 |
| Rock Stacker Join Date: May 2005 Location: Las Vegas
| Sponsored Links | |
| | #2 |
| Dirt Addict ![]() Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
| Where are they breaking? Jay |
| | #3 |
| They either break right at the hole where my support and links mount, or right at the bend. |
| | #4 |
| Rock Stacker Join Date: Sep 2004 Location: Auburn University
| I'm working on fitting some 1/4 scale servos on my clod and I'm going to make new axle braces that mount similar to the stock ones but also mount to the top ear of the knuckle. I've had a couple tubes break there and I figured if I was going to make new braces might as well beef up the axle top. |
| | #5 |
| Quarry Creeper Join Date: Aug 2005 Location: Asia
| get aluminum knuckles and c axle tubes. those support braces you have pictured will help a bit, but on high impacts the c axle tubing still breaks. |
| | #6 |
| Quarry Creeper Join Date: Nov 2004 Location: MANVILLE
| i use the ttr axle brace combo and it does help.at the last mj i went to me and my son broke 3 tubes at the race but didn;t find out they actually broke untill later on after i got home and getting them ready for next years race.the braces actually held the c-brace together and if i didn't look real close i would've missed it.it drove fine like that but i changed them as i didn't want them to let go at a race. i like the ttr cause they use a brace on both sides of the tube and the cf support(which can be bought with out if you don't want it) http://www.thundertechracing.com/axelbrc.htm Last edited by SPEED_RACER; 09-12-2005 at 11:26 AM. |
| | #7 |
| yes those double support does help a lot, but im cheap so i fabricated me some using aluminum. |
| | #8 | |
| PapaGriz Yo ![]() Join Date: Apr 2004 Location: Planning
| | #9 |
| I wanna be Dave Join Date: Apr 2005 Location: It's good to be a Pirate!
| I talked to Fish about it also and he says the stub axle may be in a tiny bit more than it should. That would cause binding when you turn. |
| | #10 |
| Thanks for the input guys. Got 8 replacements coming from Tower, so will give them another go. |
| Thread Tools | |
| Display Modes | |
