| | #1 |
| Rock Crawler Join Date: Dec 2004 Location: www.ORCRC.com
| I've got some Gaint Tracs mounted on narrowed Clod rims (no spacers) on my Project Xerox (if you can beat them, join them). BTW I know the body is FUGLY - its only temporary... And I'm have a hard time steering these meats! Up front I've got a one Blue Bird BMS-660MG w/ Heat Sink Servo rated at 195 oz-in. @ 6V with a Kimbrough 124 black servo saver and behind the axle steering. Out back I've got two Blue Bird BMS-630MG servos rated at 195 oz-in. @ 6V with two Kimbrough 124 black servo savers and normal steering. For electronics I'm running a 7.2V 3300 mAh SubC main Battery pack to a Super Rooster with no recevier pack. I've ran a 9.6V 1100 mAh 2/3A main Battery pack and it seems to perform the same as the large pack. The rear definately steers better then the front but it still not great. Every time I put a solid servo arm on the front servo I end up blowing a servo (on my previous clod chassis') so I rather not go that route. and the rear with two servo savers compared to two solid arms is almost identical performance, so I choose to go with the servo savers. So do you guys have problems steering with Gaint Tracs? Is there a stronger servo saver I should be using? Is it worth narrowing the GT's? I don't want to loose my tire performance. plus I hate cutting up these rare tires. Are these BlueBirds really putting out that much torque compared to a equal Hitec or Airtronics servo? Any ideas? Sorry if this is in the wrong spot to post this but I didn't know where to post this question since its Tire and Servo related. |
| Sponsored Links | |
| | #2 |
| 06 Super National Champ ![]() Join Date: Jun 2004 Location: Tennessee
| As much as you can afford. |
| | #3 | |
| | #4 |
| Read your thread title, based my reply on that. (even though I read the whole post) I run without servo savers. |
| | #5 |
| Every time I run without servo savers I toast a servo! Thats gotten expensive, FAST! |
| | #6 |
| I wanna be Dave Join Date: Apr 2005 Location: It's good to be a Pirate!
| Maybe you should consider how you drive as well. No offense but if you have a wheel trapped and you are trying to steer you are going to break something. I usually try not to steer unless there is some kind of movement. And use common sense when you have a trapped wheel. |
| | #7 |
| Most of the time the servos break from rollovers.......Not from Raw Abuse. |
| | #8 |
| Rock Crawler Join Date: Aug 2005 Location: Idaho Falls
| I've seen guys not run servo savers and well, they've broken servos. I run servo savers and have had no problems. |
| | #9 |
| Quarry Creeper Join Date: Jan 2005 Location: Carlisle, KY
| I run 1/4 scale servos and no servo savers. I have no problem at all. |
| | #10 |
| TEAM MODERATOR ![]() Join Date: Jul 2004 Location: Chit Chat
| I do fine with 645s & Kimbroughs & GTs. Float like a feather... steer while moving. I too kill servos out of the blue. So servo savers are a must. I don't use weights. All my electronics / batts are on, or above the front axle. I dunno... |
| | #11 |
| The Wheels Keep Turning ![]() Join Date: Jan 2004 Location: Phoenix, Arizona
| don't narrow the giant tracs. They suck narrowed. I don't have any problems turning mine, but then again i'm running a 333 oz-in robot servo and ofna heavy duty servo saver. |
| Thread Tools | |
| Display Modes | |
