02-06-2009, 12:47 AM | #1 |
Pebble Pounder Join Date: May 2008 Location: Vancouver, Canada
| Long Pinions?
Im building my first crawler and have 55t motors with adjustable motor mounts and 6tooth pinions. Do I need to use long pinions ?
02-06-2009, 01:05 AM | #2 |
Quarry Creeper Join Date: Dec 2007 Location: stevens point
| yes
Yes you will need the long pinions since you are using the adjustable motor mount it is a little thick and moves the motor out so you need the long pinion to make up for that.
02-06-2009, 03:05 PM | #3 |
Thanks I really appreciate your help.
02-06-2009, 03:25 PM | #4 |
Quarry Creeper Join Date: Jul 2005 Location: pleasant ridge
i use standard pinions and never have had a problem.
02-06-2009, 03:35 PM | #5 |
Quarry Creeper Join Date: Nov 2006 Location: RENO, NEVADA
02-06-2009, 06:48 PM | #6 |
Rock Stacker Join Date: Aug 2008 Location: Austin
You can always move the pinion out on the motor shaft.
02-06-2009, 07:51 PM | #7 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
If you already have standard pinions, try them 1st. We've never had an issue using standard pinions with our adjustable mounts. I know other brands are much thicker though. If you're buying new anyway, getting the longer ones will ensure they'll work with just about any combination. |
02-06-2009, 09:06 PM | #8 |
agreed, i use CPE mounts and standard pinions.
02-07-2009, 10:28 PM | #9 |
Thanks again Ill try the ones i have.
