02-18-2009, 05:46 AM | #1 |
Quarry Creeper Join Date: Nov 2007 Location: Northern
| What parts build a strong super axle?
I have a set of clod axles in the mail. They will be used for a super build. I have the wheels and 23mm adapters. I plan on using handwound 45t lathe motors and this is what I plan on purchasing: Integy metal gear set Thundertech adjustable motor mounts Thundertech CVD's Are aluminum knuckles, bearing kits, and aluminum axle tubes needed to strengthen the axle? thanks |
02-18-2009, 06:00 AM | #2 |
Not needed really but help, depends on how hard you run your rig really., If you take alot of falls the tubes and knuckles would be a good investment. If your running lathe motors the metal gears are not really necessary.
02-18-2009, 06:13 AM | #3 |
Metal gears aren't needed even with a set of handwounds like holmes or JP's?
02-18-2009, 06:27 AM | #4 |
Pebble Pounder Join Date: Nov 2008 Location: Virginia Beach
I have broken several stock tubes and knuckles, not to mention when you snap the tube in half it bends the shaft to. I switched to all aluminum and will never build another clod axle without it. I run stock gears and a CPE locker assembly. I have never had any issues with the gears.
02-18-2009, 07:56 AM | #5 |
Quarry Creeper Join Date: May 2005 Location: Crossville,TN
I now build all my Clods with the metal tubes but still use the OEM gears. Using this combination I have experienced no problems, no breakages. Carl |
02-18-2009, 08:20 AM | #6 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
I'd recommend the stock gears, plastic gearcase, and aluminum tubes and knuckles. Bearings (rubber shielded) also. I know of many high power combinations running our lockers and stock gears without a failure. Those gears are REALLY strong and can stand up to a lot of abuse. |
02-18-2009, 09:00 AM | #7 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
I would run stock cases,Jp's knuckles,Integy tubes,CVD's. As for the gears I think it depends on what pinion you plan on using. With a good 3 cell lipo 45t or 35t motor if you use 6 or 7 tooth pinions I would go with metal gears if you are going to use a 8 or 9 tooth pinion plastic gears work great. Last edited by joesbruiser; 02-18-2009 at 09:20 AM. |
02-18-2009, 09:02 AM | #8 |
RCC Addict Join Date: May 2006 Location: China Grove, NC
hey I have broken a couple stock gears sets, even in comp setings. I have the full integy gears and have not had a failure in 2 years now. If I were to buy everything new now; - CVDs front and back - Integy spool (leave the other gears stock) - ALU axle tubes and knuckles (maybe even the case depending on the style of servo mounts) - good bearings |
02-18-2009, 06:36 PM | #9 |
I stripped both sets of Gears in my Super Clod at Crawlaplooza with 60T CrawlMax's.. With in just 2 courses and never even jammed them up. I set the crawler down for the 3rd course and never made it past the start line. Not even the Warriors. I was on 8t and 3 cell Lipo.... If you make the jump to 3 cell.. Metal gears are a must. Last edited by run2jeepn; 02-18-2009 at 06:39 PM. |
02-18-2009, 07:03 PM | #10 |
Pebble Pounder Join Date: Dec 2007 Location: Canby, Oregon
I'm running Integy Al gears for em all. Al Tubes, JP Al knuckles and TTCVD's |
02-18-2009, 08:26 PM | #11 |
for those running TT CVD's, will they work with the integy metal spool? Also, I have a set of 23mm adapters...specifically these. http://www.tcscrawlers.com/Hot-Racin...8-p-16515.html Am I going to be ok or do I need to buy something else to make them work. |
02-18-2009, 10:28 PM | #12 |
You will need some Longer Bolts, not Barrel nuts to use those Adpaters. The Integy Spools work fine with TTR CVD's.
02-19-2009, 08:47 PM | #13 |
well, I placed a few orders... parts will be added to both axles TT CVD's TT adjustable motor mounts Yeah racing bearings JP knuckles Integy axle tubes Integy aluminum gears 7,8,9 tooth pinions Axles powered by a set of JP's Warrior 2 45t's |
02-20-2009, 02:58 PM | #14 |
been running for 2 years now with stock parts, gears, knucles cases etc. never broke a single part. lots of 1st and a state championchip in the process. clods are just bad ass like that i run 55s on 6 cells. |
02-22-2009, 12:13 AM | #15 |
| Thats why ....with 55T's on 6 cells. The insides will last. The axles C's always broke on me. Even on my Old 2.2....:?
02-22-2009, 10:31 AM | #16 | |
RCC Addict Join Date: Nov 2006 Location: southaven
thats the set up right there | |
