Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: Gear ratios with Lathe
Old 09-25-2005, 06:36 PM   #1
06 Super National Champ
JasonInAugusta's Avatar
Default Gear ratios with Lathe
Which gear ratio do you guys think is "best" for a 55t?
Here's what each pinion gives as a drive ratio.
8T 48.89:1
9T 43.46:1
10T 39.11:1
11T 35.56:1
12T 32.59:1
13T 30.08:1
14T 27.94:1
15T 26.07:1
16T 24.44:1
I'm running the 8T with lathes (~49:1).
What's everyone else running?
JasonInAugusta is offline   Reply With Quote
Old 09-25-2005, 06:52 PM   #2
73.4 :1 with lathes on 8.4V
Destroyer is offline   Reply With Quote
Old 09-25-2005, 06:54 PM   #3
13t 30.08 at 8.4v I love it this way.
Used to have it with 9t but was way to slow
Cole82 is offline   Reply With Quote
Old 09-25-2005, 06:57 PM   #4
Team *
62PYRO's Avatar
Smile
Hey,
I'm Running The Same Gears,iguess Thats The Ticket.aren't You The Same Jason From Rcdriver?if So,thanks For Getting Crawlers Out In The Public Eye.i'm Tired Of Other Mags Just Being Oversized Ad Pages And Butt Kissers.that's Also Why Rcdriver Is The Only One I Subscribe To.
Keep Up The "great" Work.
62pyro
62PYRO is offline   Reply With Quote
Old 09-25-2005, 07:16 PM   #5
Yup, that's me. Thanks!
Just wondering what the popular opinion on gear ratios was right now.
I'm in the design phase of a new crawler for '06...trying to nail down ratios before I get into all the time spent in front of the mill.
Old 09-25-2005, 07:28 PM   #6
CSR
I'm running 13T on my 2.2", works great!
CSR is offline   Reply With Quote
Old 09-25-2005, 08:48 PM   #7
TCS/Holmes Hobbies
SVEN's Avatar
I am using the 8T 48.89:1
Have you seen the new reductions from RC4WD? Maybe a set up with the reductions, lathes, and more than the typical amount of voltage would work .
SVEN is offline   Reply With Quote
Old 09-25-2005, 09:25 PM   #8
13tooth for playing around on the hills and 9 for rocks.
rockcrawler_101 is offline   Reply With Quote
Old 09-25-2005, 09:29 PM   #9
It's a setup!
jason's Avatar
I run 8 tooths, but I also run 8 cells.
jason is offline   Reply With Quote
Old 09-25-2005, 09:49 PM   #10
I have found that while 73.4: 1 is great for real tight technical stuff, as well as climbs and especially descents, it is a little too slow for slicker rock where some wheelspeed is required. (Like at Bucks Pocket) I'm going to bump it up to around 60: 1 and see what happens.
-Destroyer
Old 09-25-2005, 10:17 PM   #11
Dirt Addict
roktoy's Avatar
Location: Stumblin' thru the parking lot of an invisible 7-Eleven
For AZ crawling I like 9T pinions with the lathes on 7.2V.
Jay
roktoy is offline   Reply With Quote
Old 09-25-2005, 10:34 PM   #12
I have always liked 10 tooths myself with the 55turn lathes on 7.2, good balance of wheelspeed with plenty of torque.
So my answer would have to be 39.11:1
Heavy
Heavy is offline   Reply With Quote
Old 09-25-2005, 10:40 PM   #13
TEAM MODERATOR
EeePee's Avatar
8 cells, 10 tooth in front, 9 tooth in back.
From experimenting, in my parts of the woods, it's a good compromise between wheelspeed and torque.
If I had to choose between one or the other, I'd choose 9 teeth pinions.
EeePee is offline   Reply With Quote
Old 09-26-2005, 08:45 AM   #14
8 tooth front and rear. I am also running 8 cells.
FrankyRizzo is offline   Reply With Quote
Old 09-26-2005, 02:44 PM   #15
RIP Buster
badger's Avatar
I installed 8t pinions and lathe motors and 7 cell packs in the one I am building. I should know how I like it this week.
badger is online now   Reply With Quote
Old 09-28-2005, 05:08 PM   #16
Thumbs up
thanks for posting this ... great information
jeepster is offline   Reply With Quote
Old 09-28-2005, 05:09 PM   #17
I am running this set up and it seems to work great
Old 09-28-2005, 05:58 PM   #18
10 in front and 9 in the back,but with p-94 style end bells it's too fast for my liking i wish i could find some 8t pinions that are cheap.i may wind a 60 turn motor to slow it down
chafey is offline   Reply With Quote
Old 09-28-2005, 06:32 PM   #19
PapaGriz Yo
Grizzly4x4's Avatar
I like 10 in the front 9 in the rear too on my super crawler.
With 9.6V this makes a kick *** setup.
On my 2.2 clod I run a 14 up front and 13 in back with 5" tires. Again, with 9.6V you get good low end grunt and tire speed when you need it.
Grizzly4x4 is offline   Reply With Quote
Old 09-29-2005, 09:43 AM   #20
RC4wd sells them on ebay one at a time so if you only need one to try a 9/8 combo, plus the ones he sells are longer than any others you can buy so you get more gear mesh and the price isn't to steep
http://cgi.ebay.com/8-Tooth-Pinion-G...QQcmdZViewItem
