02-28-2009, 12:38 PM | #1 |
Pebble Pounder Join Date: Aug 2007 Location: Roosevelt
| super stick help
I am planning on building a stick cawler and was wanting to know what style frame is better the round tube with shocks or a piece of aluminm u-channel. I have a piece of u-channel i was thinking of using. is there any pros & cons to using this style frame or should i spend the money on the tube style?
02-28-2009, 01:11 PM | #2 |
Quarry Creeper Join Date: Apr 2008 Location: Fondy, WI
the u-channel frame that you are referring to is a "pimpcane" sold by jpcustomrcs.com the "stick" is sold by tcscrawlers.com these are 2 completely different style of chassis and work differently in different circumstances. the stick does require some tuning w/ shocks and springs, but the pimpcane requires no set-up other than tires and foams. the pimp cane is better for someone who doesnt want to tackle any tuning and is also far cheaper. both are great chassis. |
03-01-2009, 09:39 AM | #3 |
thanks i think ill go with the pimp cane for now cuz its cheap .
03-04-2009, 06:12 PM | #4 |
Newbie Join Date: Dec 2007 Location: York
you can go to the hardware store and by squarestock aluminum and use that also
03-05-2009, 12:36 PM | #5 |
The square stock wont twist like the u-channel will. the square stock would work for a normal frame but the u-channel is the key component it the pimp cane design.
