02-28-2009, 03:17 PM | #1 |
RCC Addict Join Date: Jul 2008 Location: Sin City
| Culetto's First Super
Im building a Super class for the first time so i started this to ask lots of questions of all the clod guru's out there. So far i only have some clod axles with bearings and upper link mounts. Most of my questions are related to parts compatability and the axles. I'm going to run 23mm or 17mm wheel hex adapters. With TTR CVD's will they fit? Do they need to be specific ones to fit the 8mm axle or can they just be drilled out? Im probably going to run 40series wheels/tires. Will 55t motors with 6t pinions on 11.1v be low enough to get it up the rocks? I also have a pair of OG Revolvers sitting here i could throw in it if needed. |
02-28-2009, 05:43 PM | #2 |
Rock Crawler Join Date: Feb 2008 Location: CHESAPEAKE, Va
sounds like a good set up to me. glad to see new interest in supers |
02-28-2009, 05:58 PM | #3 |
Quarry Creeper Join Date: May 2005 Location: Crossville,TN
From reading your initial post it sounds like you are heading in the right direction. One of the best things about the Clod is that there are tons of after-market parts. Of course, not all of them are applicable to crawlers but lots can be readily adapted. Keep this thread updated so we can follow your progress and cheer you on. Carl Mitch, I sent you a PM about the adapters I mentioned last weekend. |
02-28-2009, 06:36 PM | #4 |
Pebble Pounder Join Date: Nov 2008 Location: Virginia Beach
Great start on a SUPER. Glad to see we are getting some attention. I would recomend going with the 17mm hex. It will leave you with more wheel options IMO.
03-01-2009, 02:37 AM | #5 |
| Yes but will a standard 17mm wheel hex adapter fit over the TTR CVD or will it have to be drilled out? I cant tell from the pictures on various sites what the setup is.
03-01-2009, 02:42 AM | #6 |
TTR had 17mm hex's for there CVD's... $25 http://thundertechracing.com/cvd1.htm Or are you talking about the Adapter mounting to the CVDs? These will bolt right up, but you will need to buy Bolts instead of the Barrel nuts that come in this kit. http://rc4wdstore.com/product_info.php?products_id=466 Last edited by run2jeepn; 03-01-2009 at 02:44 AM. |
03-01-2009, 09:11 AM | #7 |
Quarry Creeper Join Date: Nov 2007 Location: Northern
TT CVD's come stock with plastic 12mm outer drives. You can buy the aluminum ones... Item MIP-CB12. From there, I have the H.R. 15mm offset adapters to use 23mm wheels. http://www.jpcustomrcs.atomicshops.c...74/6427654.htm |
03-01-2009, 10:02 AM | #8 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
If you are running TTR CVD's almost all buggy and truggy wideners will work great and can be had in 17 or 23mm in a bunch of different widths.
03-01-2009, 11:08 AM | #9 |
Pebble Pounder Join Date: Feb 2006 Location: Dallas, Ga
Its awsome to get new interest in supers. In my opinion they are the heart and soul of rc crawling becasue if you want it you must find parts and build it. For the most part no walking in to the LHS and coming out with a RTR super. For your wheels and tires keep an eye on those tenn. boys, panther appears to be they way to go. I have run 14mm on my custom axle and clod based supers with no problems yet. I run 14mm because the first set of wheels were MGT. Good luck, keep us up to date with some pics when you can. |
03-01-2009, 12:19 PM | #10 | |||
03-02-2009, 02:53 AM | #11 |
Pebble Pounder Join Date: Feb 2005 Location: HAWAII
wat is the pitch of the 6t pinion that u r using? also where did u get it from?
03-02-2009, 08:18 AM | #12 |
RCC Addict Join Date: Nov 2006 Location: southaven
03-02-2009, 08:24 AM | #13 | |
I believe the cross pins are the same because I have used a number of different off set wheel adapters from the 1/8th scale truggies and have never had a problem. | |
03-02-2009, 06:28 PM | #14 |
And so it begins. Ebay special. Full ball bearings (though i havent taken them apart yet so who knows.) One of them is locked already (again, who knows how it was done) Upper 4 link mounts (Look home made) 14mm hexes (wasnt listed in the auction so thats a bonus to start) |
