03-04-2009, 07:52 PM | #1 |
Quarry Creeper Join Date: Nov 2006 Location: RENO, NEVADA
| help me redo my clod
well my clod works alright the way it is now, but im not to happy with it..when i 1st started it i didnt have very much money to spend on it, but some things have change & i have a new job so im hoping to buy at lest one or two parts every pay check.. hows this sound so far? what else should i do?? 1. jp knuckles 2. cvds 3. aluminum gears 4. aluminum axle tubes 5. sidewinder esc 6. rear dig 7. mayhem wheels 8. jordans thanks |
03-04-2009, 08:19 PM | #2 | |
RCC Addict Join Date: Nov 2006 Location: southaven
03-04-2009, 08:24 PM | #3 |
yes 2.2 heres what it has now 1. Pimp Cane 2. BTA steering kit 3. adjustable motor mounts 4. 645mg steering servo 5. traxxas evx-2 6. 65t motors 7. two 7cell batteries 8. Deans Wire 9. Deans Plugs 10. Moabs 11. Ax10 beadlocks 12. TCS antenna holder 13. lead weights 14. star cut foams 15. stock pinion gears 16. cr-01 body post 17. Futaba radio gear 18. locked diffs 19. shaved front axle 20. stock car body 21. rear steer locked 22. steering stops shaved |
03-05-2009, 01:27 AM | #4 |
Ditch the Jordans for some White Rovers... Get the TTR CVD's and the wider 2.2 Clod 14mm mayhem Wheels. The ones that are 1.25in wide not 1in.. Replace the Knuckle bolts with Set screws. Just use a small Dab of CA glue to hold the Bushing in. Make sure to get the Small Knuckles and Tubes for the Clod. Also do the 14mm LST2 hex mod... 50T with 8t Pinions on 3 cells is a good Combo.. Ditch the two battery backs... To much weight and space taken up. Run a Castle Sidewinder or Mamba Max. Also get a much better Servo.. The 645 is junk and strips out to easy. Hell the TP946R's have better gears. Last edited by run2jeepn; 03-05-2009 at 01:30 AM. |
03-05-2009, 10:21 AM | #5 |
Newbie Join Date: Dec 2008 Location: Pittsburgh
Do you have any pics of your rig? I'm waiting for my pimp cane chassis right now so I'm collecting parts. On the fence whether to go Series 40's w/ narrowed rims or 2.2. Have you had any issues with clod stall?
03-05-2009, 10:40 AM | #6 |
well i already did a deal for the jordans with another person on here, but if the woman lets me i might get a set of rovers also. i think ill have to wait on lipos intell i get a better charger every thing else sounds pretty good. also whats a good way to get the black paint off my PC? (got it in the hammer black but kinda wish i wouldnt have now) thanks |
03-05-2009, 10:41 AM | #7 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
If youre going 2.2,look into grizzly4x4 miniclod axle conversion,looks sweeet!
03-05-2009, 10:48 AM | #8 | |
& yeah i have the clod stall kinda bad, as soon as it starts to climb up the stall comes in to play, but ino my rear motor isnt in the best shape..so that could be one problems | |
03-05-2009, 10:57 AM | #9 |
| heres some bad pix |
