Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Anyone Using The Hot Racing Clod Knuckles?
Old 03-07-2009, 12:05 PM   #1
Question Anyone Using The Hot Racing Clod Knuckles?
Are they any good? Will most likely use them without CVDs in a rock racer basher brushless clod so all I need is strength to withstand high jumps etc...
I run JP knuckles in my crawler but wanted to try something cheaper in this build ...
Any info appreciated
TheHeadHunter is offline   Reply With Quote
Old 03-09-2009, 02:06 AM   #2
8-454's Avatar
I'm currently using the hr knuckles and axle tubes on my clod for the past nine months and they are holding up really well. My trucks seen some three foot falls to hard ground with no breakage.
Can't really compare them to others out there cause I haven't owned any others besides stockers.
I can post some pics if needed.
8-454 is offline   Reply With Quote
Old 03-09-2009, 07:35 AM   #3
No probs about pics ...tanks for the info ,which axle tubes are you using ...and is your inner axles stock?
Old 03-09-2009, 05:43 PM   #4
8-454's Avatar
I'm running the hot racing axletubes with stock axle shafts and a rcp diff locker.
Old 03-09-2009, 08:53 PM   #5
Thanks
Old 03-09-2009, 09:03 PM   #6
Could you post pics? I used to look at these axles before and just didn't find much about people using them.
Jacko is offline   Reply With Quote
Old 03-10-2009, 12:48 PM   #7
I run the tubes and knuckles...The tubes are awesome! The knuckles are OK...I have bent on of the arms before. granted, it was after a big fall and it didnt break...it just bent...i bent it back and its been fine since. That was a long time ago too.
All in all...I like the combo...it was relatively cheap and works pretty good.
TURBOFEST is offline   Reply With Quote
Old 04-24-2009, 03:26 PM   #8
WRXronald's Avatar
are those TTR CVD's with HR tubes/knuckles?
How are you getting them to fit... my TTR CVD's seem too wide/long and the holes on knuckle and axles "C" don't line up... ???
WRXronald is offline   Reply With Quote
Old 04-25-2009, 01:59 AM   #9
Same Tubes and Knuckles here with TTR CVD's.
Everything just bolted right up.. Was running this Combo for over 2 yrs. Not one issue with bending, Breaking or fitment issue..
Old 04-27-2009, 09:20 AM   #10
X2...they are stock clod replacement parts. all the dimensions should be the same.
Are you sure the cvd's are sitting properly into the center locker?
