04-13-2009, 08:30 AM | #1 |
Pebble Pounder Join Date: Apr 2009 Location: Worcester
| 4 Wheel steering questions
have a clod vehicle and I'm running a castle mamba max > 2 integy motors What I'm wondering about is if I want to do 4 way steering, I got a typical receiver SR 3000 Recieverhttp://www.amainhobbies.com/product_...oducts_id/3470 for a spectrum radio. I'm wondering 1. If I need a servo reverse harness and if you guys could link me to one. I can't find one anywhere 2. Do I need 2 castle electronics BEC's for 2 servos. I'm wanting to set this up so that I can just use the wheel on the radio and have 4 way steering. No switch or anything. I want to keep it simple. Thanks Last edited by knuckleslammer; 04-13-2009 at 08:33 AM. |
04-13-2009, 04:58 PM | #2 |
Quarry Creeper Join Date: May 2005 Location: Crossville,TN
A lot of that depends on if you are running digital servos for your steering. I use the HiTec digital servos and have the programming box so I just reverse one of the servos and then use a 'Y' connector and drive them with the normal steering channel. There is also an electronic piece that is a reverser and has a 'zero' adjustment and you can run both servos from the single steering channel. Here are some examples: http://www3.towerhobbies.com/cgi-bin...rser&search=Go Carl Last edited by quickster47; 04-13-2009 at 05:04 PM. |
04-13-2009, 10:52 PM | #3 | |
Here's the transmitter I bought http://www.amainhobbies.com/product_...ducts_id/29216 Last edited by knuckleslammer; 04-13-2009 at 10:57 PM. | |
04-14-2009, 07:02 AM | #4 |
Problem is I do NOT think you can mix two channels on the DX3S. Meaning, there would be no way to drive the Aux channel from the sterring input. Could be wrong on that though. But because of that limitation is why lots of folks prefer the Futaba 3PKS or the 4PK. Carl |
04-14-2009, 07:08 AM | #5 |
So what's my best option? A reverser? Thanks for the help. |
04-14-2009, 08:33 AM | #6 |
My own opinion would be to use a reverser. I used one for many, many months and never had a problem. Only reson for my change was getting new digital servos and the programmer. And this was because I was doing lots of robotics work last year. Carl What I have been using: http://www3.towerhobbies.com/cgi-bin...&I=LXMYH5&P=SM http://www3.towerhobbies.com/cgi-bin...&I=LXTHR3&P=ML http://www3.towerhobbies.com/cgi-bin...&I=LXSYU0&P=SM |
04-14-2009, 09:46 AM | #7 |
Quarry Creeper Join Date: Nov 2007 Location: Northern
You only need one BEC. Just solder the red "power" wire to the red wires for the servos.
04-14-2009, 09:54 AM | #8 | |
So I solder a wire from the + on the BEC to the red wire of the servos? so Red (+) on BEC to both servos red wire? Even if I have the reverser? I wish I had a diagram of how to set it up properly. | |
04-14-2009, 10:15 AM | #9 |
Here is my setup. Similar to what you are looking for however, I'm using 2 esc's. Simply keep the red wire from your esc connected to power the receiver. Jump the two servo's red wires to the red wire on the BEC. I don't think you need to plug in the signal and negative into the bat. port on the receiver. I don't remember if I did so. EDIT: you're using a reversing Y harness.. Just plug in normally. Are you headed to lincoln woods on saturday? |
04-14-2009, 11:48 AM | #10 |
What's happening @ lincoln woods? A comp or just a meet?
04-14-2009, 12:27 PM | #11 |
comp/trailride and swapmeet. Check it out in the RI section under "northeast". I'll have my clod there and you'll get an understanding of my wiring.
04-15-2009, 10:55 AM | #12 |
Looks like I don't need the Y harness. Here's from the manual for the radio. Was looking at the manual for the DX3S AUX Setting The Auxiliary Setting function allows trim adjustments on the auxiliary channel to be made and adjustments to mixing values on the steering to the auxiliary channel. Typically the mixing function is used in dual steering servo applications such as giant-scale trucks. The primary or controlling channel is steering while the channel that is mixed to is auxiliary. The auxiliary channel follows the movement of the steering channel based upon the mixing value that is programmed. Negative values cause the auxiliary to move in the opposite direction. Note that the AX Trim is active for the Auxiliary channel only. The auxiliary channel (Forward/ Reverse) two-position switch allows dual mixing rates that expand capabilities to include crab steering as used in rock crawling. Im just still confused as to how to setup the BEC. Do I need 2 BEC's since I'm using 2 servos? |
04-15-2009, 11:22 AM | #13 |
Newbie Join Date: Feb 2009 Location: Norcal, Davis
No you only need one BEC, positive wire can be split to several circuits. Here a good thread on BECs, with diagrams on page 10; Castle BEC- review and tech thread Here is Castles website with several diagrams and user guide; http://www.castlecreations.com/products/cc_bec.html Cheers, DC |
04-15-2009, 10:40 PM | #14 |
I posted this in the other thread, but that one seems dead. Does this look right? And do I program the BEC for 6v and that will do 2 servos? Not 9V I'm not an electronics guy, but I figured 2 6V servos require 12V but I'm probably wrong. |
04-16-2009, 08:40 AM | #15 |
Pebble Pounder Join Date: Dec 2007 Location: Canby, Oregon
Your BEC needs to be getting power from your battery. Set it for 6V |
04-16-2009, 09:58 AM | #16 |
04-16-2009, 07:10 PM | #17 |
Yes 6V will power many servos. the servos take more amps the more you add. Your voltage should stay the same
