04-22-2009, 07:36 PM | #1 |
Newbie Join Date: Apr 2009 Location: Southern
| 2 motors..
when i run 2 motors do they have to be the same? I'm new so that why i'm asking. Looking to run 1 esc with 2 motors.
04-22-2009, 07:58 PM | #2 |
Nope, plent of folks run different tooth pinions on their motors. I run different turn motors on my clod (55T front and 60T rear), however, I run dual ESCs, but that shouldnt make a difference.
04-22-2009, 09:09 PM | #3 |
Rock Crawler Join Date: Jul 2007 Location: clearfield
as long as motors (when combined) arent beyond your ESC's motor limit.. i dont see prob.
04-22-2009, 09:59 PM | #4 |
So 2 55t motors would be fine? Also, is it better to run 2 esc or 1 esc? Any benefit w/ one or the other?
04-22-2009, 10:03 PM | #5 |
would you be running them in parallel? (positive off of esc to positive of each motor, same with negative) that would give you a motor equivalent to a 27t... as long as your esc can handle a 27t.... which most esc's should...
04-22-2009, 10:29 PM | #6 |
Newbie Join Date: Oct 2008 Location: London
| benefit
one benefit to 2 esc's is (if) you are running a stick radio, you have a lot more control over the 2 motors. You can run the rear, the front, or both whenever you need.....
04-22-2009, 10:46 PM | #7 |
Mamba Max esc would be fine?
04-22-2009, 11:01 PM | #8 |
Pebble Pounder Join Date: Dec 2007 Location: Canby, Oregon
Yes thats perfect. (Actually overkill)
04-22-2009, 11:05 PM | #9 |
I like overkillalways have. Any advice on motors?
04-22-2009, 11:16 PM | #10 |
are you running adjustable motor mounts? if you are, i would try like 45t's, if you want a little more wheel speed, or if you like slow go with 55t.. what battery are you gonna run? |
04-23-2009, 01:35 PM | #11 | |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
slow???? I can rock race with twin 55t's and 8t pinions. Of course 11.1v helps I have seen allot of people run 1 esc with a 55t front and 45t rear to help combat stall. In all reality the only way to truely eliminate it is to run 3 esc's. 2 escs also give you control over both axles, this can be handy to get you out of a bind. Currently I run 1 Mamba Maxx and 0 issues, soon to be 2 mamba Maxx's and 0 issues. | |
04-25-2009, 04:57 PM | #12 |
Pebble Pounder Join Date: Apr 2009 Location: Italy
04-25-2009, 07:31 PM | #13 |
Rock Crawler Join Date: Mar 2008 Location: hillbilly illinois
04-25-2009, 08:35 PM | #14 |
Quarry Creeper Join Date: Dec 2005 Location: ST LOUIS.MO
2. 35 turn holmes motors 1.mamba monster 1. 4s lipo 1 400.0z servo. 1 castle bec no problems yet.....yet |
04-26-2009, 09:51 AM | #15 |
The problem is the money i have to spend is through Amazon (giftcard present) Going to get the Mamba Max (any other suggestions) not sure on the 2 motors and a lipo 3s. Might be dumb to ask but i have to go through Amazon. Any help app.
04-26-2009, 03:59 PM | #16 |
Quarry Creeper Join Date: May 2005 Location: Crossville,TN
Here ya' go. The three main ingredients to get you started. Mamba Max http://www.amazon.com/Mamba-Max-Brus...0782935&sr=8-3 Integy 55t Lathe Motor http://www.amazon.com/Matrix-Pro-Lat...0783014&sr=1-3 1250mAh 3S 11.1V 20C LiPo http://www.amazon.com/1250mAh-11-1V-...783059&sr=1-18 Carl |
04-26-2009, 04:05 PM | #17 |
I don't know if it's common in the US, but here in Italy in relative-low-current applications such as crawlers (on even drifters) cheap chinese LiPos are becoming the rule. You can actually find a couple of 4000mAh 15C LiPos for less than 25-30$, including shipping, on eBay if you purchase them from Hong Kong. I personally run 4000mAh 15C batteries on my drifter and 3200mAh 25C on my scaler Bug and they work flawlessly |
04-26-2009, 09:05 PM | #18 |
thanx carl
05-01-2009, 05:28 AM | #19 |
Quarry Creeper Join Date: Jan 2009 Location: North Wales, UK.
I used to run two Novak55's off one Mamba Max - stalling of the rear when trying to climb up something was a problem! Now I got two Mamba Max ESC's a Castle BEC and a (DX6i) stick radio - it's like a new rig! Awesome! Highly recommended! I wish I'd gone for motors with stronger magnets though, the Integy 55t Lathe magnets seem to be stronger than the Novak55's. IMO. |
05-03-2009, 10:36 AM | #20 |
Quarry Creeper Join Date: Nov 2007 Location: Cincinnati
even though you didn't say what kinda application you're running(2.2, super, rock racing, etc), i find my 35 turns with 9 tooth pinions to be a bit fast for my 2.2. it all depends on specifically what you're wanting to do.
