05-25-2009, 01:29 PM | #1 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
| dual rooster crawler esc ?
Is an external bec needed? Novak stated that it already has bec in the esc. I wanted to run my super with 2 rooster crawler esc with either 45turn or 55turn combo. Which is better? (45's or 55's) Do I need anything else to run this properly? My specs are so far... Locked axles (JB welded) Jpc knuckle packs with HR tubes 8 and 9 toooth pinions Axial 40 w/ XL Mombs 2 TP995 servos Dx6 tx with AR600 rx old 6 cell GP 3300 NiMH batteries Still gathering odd and ends parts such as links, bolts, nuts etc,etc... any info is apperciated. Thanks |
05-25-2009, 03:28 PM | #2 |
Pebble Pounder Join Date: Feb 2005 Location: The Aloha State....Aurite!
the novak bec is not enough to power to work the servos, so yes, an external bec is recommended................. if your still lookn for parts check out the knuckle packs that I have in the fs sec....... |
05-25-2009, 05:14 PM | #3 |
Even the esc is at 6volts/ 5amps, it's still not enought to power a pair of TP 995 servos alone? Can anyone second that I should get the cc bec?
05-25-2009, 09:54 PM | #4 |
Rock Stacker Join Date: Dec 2008 Location: Calgary-Canada
