07-22-2009, 12:49 PM | #1 |
Newbie Join Date: Apr 2009 Location: Portugal
| Need advise
Hi, I have an Integy SS01 with 2 ESC: Novak Rooster Crawler, 2 Motor: Novak 55T with an 6 tooth pinion both in front and rear, still have too mutch speed. Would I go for an 75T motor or a brushless (1000KV or 850KV), or is there a way to reduce the final ratio on the transmission, I have been looking for a diferent gear, but no luck!! Please advise Thanks PS: here is the car: Futaba 9CHP setup for dual steering, dual esc |
07-22-2009, 05:32 PM | #2 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
Well, It's integy which it blatantly copies almost everything out there, and 99% of the time, it's crap. These integy crawler is a ripoff of clodbuster gearbox and the hustler frame. The only thing I'll buy from them is the motors. You should have done research here before getting a full roller crawler. Next time stick with clodbuster gearboxes, there are tons of aftermarket parts for chassis, links, wheels, tires and so on....It'll be 1000% better than Integy. So for your question, most ppl I know runs their clods beween 35 and 55 turns, sometime 65 turn. I run mine on 45 turns.
07-23-2009, 09:36 AM | #3 |
Hi, Best way is to sell the Integy axles and buy new ones! Can you help me choosing? Can I use the same motor? |
07-23-2009, 11:51 AM | #4 |
Quarry Creeper Join Date: May 2008 Location: Federal Way/Tacoma
| Can I ask you guys a question about the rear steer setup...? Is there a radio that already has a 3ch toggle switch besides the converted TQ3...? I know its a cheap/easy way to do a toggle but is there a radio that has that already installed..? THANKS |
07-24-2009, 01:50 PM | #5 |
Hi, I use a 9channel stick radio, but you can use a 3channel radio and use a switch or a mix to turn the rear servo.
07-25-2009, 09:44 PM | #6 | |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
The Spectrum DX3R is probely the best 3 channel radio out there at this point and it has a 3 position 3rd channel. It cost a lot more than a TQ3, but it is already set up for rear stearing or for use with a winch. | |
