Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: 6 X 6 terra-pup
Old 04-21-2012, 12:30 PM   #1
Default 6 X 6 terra-pup
Hi Guys, New to the Forum, but i thought i'd show you a Build i started a few weeks ago. No expensive spending on this.
Started off with a home built Chassis and a pair of Axles
Had an old E-Savage ESC which was used to check the Gearboxes with and all was working fine
Front Axle was added and rough alignment done
Spent a few hours setting the suspension up, but still needs work on it.
Still got plenty to do on her but this is where i'm Aiming to get, Colour yet to be determined.
bl4derr1 is offline   Reply With Quote
Old 04-21-2012, 12:33 PM   #2
Default Re: 6 X 6 terra-pup
Like , crawler hueler.
vipxj is offline   Reply With Quote
Old 04-21-2012, 12:37 PM   #3
Hopefully this Link works for a short Running Vid before i put the Suspension on.
Clod Truck 6 X 6 - YouTube
Old 04-22-2012, 03:58 AM   #4
Cool build man, i'm following this one. for some reason the more axles the more i like
djoefromreal is offline   Reply With Quote
Old 04-22-2012, 11:38 AM   #5
Thanks guys, still struggling a bit with the steerig tho' Axles widened approx 15mm either side and with a 20kg servo she still seems lazy ? Should the Tyres have a foam in them as it could be there's so much Rubber on the Ground.
Old 04-23-2012, 12:20 AM   #6
Are you hoping this rig will float? kinda like the 1:1's do? Then I would try and do a low air pressure in the tire, rather than foam.
The Jackalope is offline   Reply With Quote
Old 04-23-2012, 12:22 AM   #7
That would be awesome if it floated.
Rocklobst3r is offline   Reply With Quote
Old 04-28-2012, 05:11 PM   #8
Well started the Body, long way to go but it's a start !
Need to cut 1/2" off the bottom of the front ( little to deep ! )
Old 04-28-2012, 07:57 PM   #9
dude the the coolest thing done yet to some clod axles just wow also try see if you can fit a rc in bed like a 1/16 or something any way cool build I'm watching this for sure
jesseRS10comp is offline   Reply With Quote
Old 04-29-2012, 07:02 AM   #10
Well Guys a few hours spent on her today. Windows Cut Doors Hinged. Unsure about cutting rear Quarter windows tho' ! yes/no ???
Anyways a few more Pics.
jesseRS10comp, Can fit a 1/8 Buggy ion the Bed it's so Big !!!
Old 04-29-2012, 07:25 AM   #11
wow man once its built up put your trucks or car on it and shoot some video and good luck with the build i will follow this one
Old 05-01-2012, 01:11 PM   #12
And a bit more ! front end and wheel Arches done in Styrofoam, Hinges for doors arrived through the post this morning.
Lighter next to wheel for proportion.
Thinking this is more 1/6th scale than anything else now ( well at least i can use Action Man Figures now ! )
Old 09-20-2012, 01:33 PM   #13
This thing makes the clod tires look SMALL!
GRTrailRider is offline   Reply With Quote
Old 09-23-2012, 09:08 PM   #14
Tzi
OMG, its massive!! Do like!
Tzi is offline   Reply With Quote
Old 09-23-2012, 09:14 PM   #15
Tzi
Clod axles never had the best steering angle anyway... but you could add some rear-steer to get the turning circle a bit tighter.
20kg servo should be more than enough to turn stock clod tyres, but you might need to get an BEC to power it properly otherwise it wont be as strong as it says on the box
Castle creations CC-BEC is one of the best and also smallest BEC's, but you can get cheaper ones that will do just as well. They are however often bigger, but I dont think space is going to be an issue for you
With a stack of spare aluminium and 6 spare clod axles on my shelf, I'll be watching this build closely
6 X 6 terra-pup - Similar Threads
our new pup. .. . for now. IDnewcrwlr Chit Chat 9 12-16-2009 12:25 PM
New pup wrx-n-ktm Chit Chat 11 03-03-2007 03:33 AM
