![]() | #1 |
Rock Stacker Join Date: Aug 2005 Location: portlandia
I was woundering if when running 2.2s you have clod still as bad as you do when you us 40 series or big tires??? thanks Dan |
![]() | #2 |
Im Brandon ![]() Join Date: Feb 2005 Location: Colfax, CA
The weight of the truck is still about the same, so yes it will.
![]() | #3 |
Quarry Creeper Join Date: Jun 2004 Location: Boaz
I have been running my clod as a 2.2 for quite some time with a good bit of clod stall, I thought. This weekend while tinkering around I stuck on a set of giant tracs and it had alot more stall and it was easier to get it to stall. I would say that the leverage the tire has is the defining factor on the stall.
![]() | #4 | |
| ![]() Quote:
![]() | #5 |
Rock Crawler Join Date: Jul 2004 Location: Mt.View CA
I played around with the clod stall, getting the ESC wires all the same length, thing like that when i had stock narrowed tires on it got some of it away. Then i slapped some 2.2's on it and there was very little clod stall. the weight does play a factor but so does the strian of the tires on the electronics, so a smaller tire will cut down on the axle strain and lessin' the clod stall. |
![]() | #6 |
Thanks i will keep this in mind.
![]() | #7 |
A way to fight clod stall is to wire your rear motor first and then run your wires to the front motor. ![]() ![]() |
![]() | #8 |
You can also make it happen a little less by switching to a shafty.
![]() | #9 | |
| ![]() Quote:
I think I'm going to be sick! ![]() ![]() ![]() | |
![]() | #10 |
Quarry Creeper Join Date: May 2005 Location: lost in vintage tamiya land.
if you ran dual esc's wouldn't it kill all the stall?
![]() | #11 |
One thought that i have... I have no idea if it will work but here it goes.. You take a two recivers and run the same crytals in the 2 recivers and the same in you remote. Then you hook on of the Esc's up to 1 recivers and the other to the one that is left. This will eliminate the stall but will force to to run 2 batts or you could make a spliting harness to run the two esc's. Tell me what you think of this idea? |
![]() | #12 |
It is still going to stall under a bind. Being as there is no solid link between the front and rearends. But running 2 esc's should help. You don't need 2 recs though. Just run a y harness from the escs to the rec.
![]() | #13 |
Newbie Join Date: Jan 2006 Location: parkersburg
| ![]() lmao or just run a shafty lol u had to get in there w/ that huh lol |
![]() | #14 | |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
| ![]() Quote:
What I did on my stick...I ran 8 cells and really never had a problem. Sometimes stall is welcome on extreme inclines because it will keep you from flipping over. I don't think you would have an issue with 2.2's because the tire would spin due to the fact you have the same torque on the smaller wheel. | |
