06-15-2010, 05:17 PM | #1 |
| ~TSS~ 2.2 Clod Cane
well decided to get out of super for a bit, and jump to 2.2 this year. while awaiting the new axial i decided to build a clod to play with. started collecting parts, and ive got most everything in now. axles: clods from my super wheels: custom (germany) tires: rocx (for now, sedonas later for more height) chassis: pimp cane with flipped rear servo: HS 645 (well see if thats enough motors: 55T esc: BR-XL body: Proline crowd pleaser |
06-15-2010, 11:33 PM | #2 |
Those wells are slick...
06-16-2010, 12:14 PM | #3 |
Rock Stacker Join Date: Dec 2008 Location: Ogden
Dude I need to build another clod. I have had bullys and HR's and i just cant seem to find anything that is as light and smoothe as a set of clods can be. Lookin good dude, I'm really diggin those wheels too. |
06-16-2010, 01:40 PM | #4 |
Pebble Pounder Join Date: Jan 2010 Location: Glenview
Dude sell me your super wheels/tires, you are already on the thread where I'm building my clod |
06-16-2010, 02:23 PM | #5 |
haha i thought about it, i have all the exact stuff you were looking for. looking forward to building this one. probly wont have time 'till next week though. |
06-16-2010, 03:02 PM | #6 |
06-16-2010, 03:13 PM | #7 |
Definitely some sweet wells.
06-16-2010, 03:43 PM | #8 |
Where did you get those wells at? Those are cool.
06-16-2010, 04:36 PM | #9 |
| narrowed axial 40 series with custom machined rings you can see them here http://www.rccrawler.com/forum/showt...&highlight=TSS |
06-16-2010, 04:36 PM | #10 |
lol glad ya like my wells |
07-11-2010, 06:07 PM | #11 |
a little bit of progress. chassis on since the raised area between the grooves was too narrow for wheel weights i got creative. 3/16" solid steel disks they weigh 1/4 pound each. the bulge of the tire should cover them not widening or making clearing gates any tougher. i scuffed them and painted them black (no pics) obviously it also moved the weight out too. may not work, but ill give them a shot. |
07-12-2010, 11:50 PM | #12 |
Hey Corey why not stick the weights inside the stock clod knuckles, they is a ton of room in there. |
07-13-2010, 09:57 AM | #13 |
cause im a little different. this should move the weight out too. if this dont work, ill definatly give that a try, thanks.
08-12-2010, 09:16 PM | #14 |
Quarry Creeper Join Date: Jan 2009 Location: Pacific Northwest
Cool start to a stick! Subscribed! |
08-14-2010, 12:37 AM | #15 |
Newbie Join Date: Aug 2006 Location: jacksonville
nicce.. |
02-13-2011, 01:25 PM | #16 |
finally made some progress. should be done this week. |
02-13-2011, 04:58 PM | #17 |
Looking good. They sure are fun to drive.
02-15-2011, 01:31 PM | #18 |
got me some 2 stage foams made. the inners are some rock hard jconcepts memories i had, that i narrowed, and then cut down the outside diameter. the outside is super soft 1" craft foam from hobby lobby that i cut into strips. i got them all mounted up in the wheels last night and they came out REALLY good. couldnt be happier especially on my first attempt. for some reason the pic makes everything look crooked and uneven but they are damn near perfect in person. |
02-15-2011, 05:59 PM | #19 |
got the tires glued up and put them and the weight disk. on the rocks! its really well balanced. a bit heavy though. over 6lbs. the wheel disks alone are 1lb though. could definatly use some 6" tires to clear the rear diff. i cut a slit down the backbone, between the axles, to help flex and it really seemed to help. it also got rid of any unloading or spring back. huge improvement. ill be curious to see how long the backbone lasts after a few comps with the cut. |
02-15-2011, 06:11 PM | #20 |
Looking good. Like you said, some 6" tires would probably help this rig out by getting those diff cases up higher.. What about filling the clod knuckles with lead/brass and get the weight off the spinning tire? I do like your weight disk though! I haven't had a stock clod knuckle in my shop in a while, can't remember if that will work or not. Edit: Dah, I just saw that Shelby posted the same idea! ... Last edited by Szczerba; 02-15-2011 at 06:21 PM. |
