06-24-2010, 02:12 PM | #1 |
Quarry Creeper Join Date: Mar 2006 Location: Lutz
| Clocking Clod axles?
Hey guys, As im sitting at work with nothing to do, i have another Clod based Super that im going to build. I kind of know what chassis and stuff im going to use. But i got to thinking, the Bergs can clock their axles (with minor mods of course) so can the Clod axles be clocked as well in the same fashion? I have noticed when i take my Super out crawling that the gear box and motor usually gets hung up a little bit. I know this seems like a stupid question and im sure someone has done it lol So hopefully someone will chime in on this. I do understand that i`ll have to modify the upper links to accept the new angle of the gear box and all. |
06-24-2010, 07:11 PM | #2 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
Yes, you can lentghen up the upper links, however it'll contact the case much sooner. My fix? Get the defiance racing upper mounts. I use it and works great... Just about same concept with berg and bullys. Here the link to it.... http://defiance.rcmt.net/ Gotta call them to order some. I think it's still 30 per pair. A tip, it will not work with hot-racing motor mounts, but the thunder tech style motor mounts works perfect. Hope that helps ya! Last edited by Mudsy; 06-24-2010 at 08:29 PM. |
06-25-2010, 07:43 AM | #3 |
That certainly does help me out! Thanks Mudsy! Never would of thought to have an upper link mount like that. .....i was just thinking also, couldnt you just put a slight bend in the upper links to compensate for the clocked gearbox? Its just a thought, im not sure if it will throw off and angles or anything in the suspension itself with having the links bent like that.
06-26-2010, 10:46 AM | #4 | |
I have done that with bend links......it works ok. It really depends on what chassis you're running. It'll work just fine with tvp, but not maybe not tube or bodiless chassis. I just perfer shorter links due to better looks and more clearence for my Beetlejuice chassis. | |
06-26-2010, 10:36 PM | #5 |
Yea i have a bodiless chassis, so maybe i`ll use the top link from defiance. Thanx!!!
