08-31-2010, 03:46 AM | #1 |
Newbie Join Date: Aug 2010 Location: akron
| what do do with the clod on the shelf.
Hello all, thanks for any replies. Let me first say,I have done lots of searchs and found nothing conclusive. I have an old clod eyeballing me from the shelf to do something with it. I would love to build a super out of it. but axle parts and even chassis are getting harder to find. I really like the hustler chassis, it's out of stock. I've thought about building an oldschool monster flatbed with a bullhead body to haul my creeper out to my rock pile. Or possible just restoring it for a shelf queen. Basically, Is it worth building a super with basically stock axles? or should I just build a custom hauler out of it? |
08-31-2010, 01:34 PM | #2 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
A super with stock axles can work but, like anything, add big tires and lots of load and stuff starts breaking. First you will strip the hex on the main gear so you will replace it with steel gears, then you will start snapping axle shafts so you will need to get some thundertech racing shafts... next you will break a c or a knuckle so time to get aluminum. After that you are left with original gear cases. By no means am I trying to tell you not to build one... supers rock and I have built several. Personally I would loook at some stick builds. I know I have done a couple on here that include some very detailed information. And they are way easier to build than they look. A drill, tap and dremil are all you need. |
08-31-2010, 04:23 PM | #3 |
thanks for the reply. I tossed around a stick build. I might be missleading by saying I want to keep axles stock. I should say. Most upgrades seem to be obsolete now. If I could get shafts and gears, I would. Every major vendor seems to be sold out of Most parts. It might be smarter to buy some bully axles or something similar.
09-01-2010, 05:53 AM | #4 |
check thundertechracing.com for axle shafts and adjustable motor mounts, Crawford performance for servo mounts and as much as I hate to say it, Integy for tubes. I think the gears I used before were either axial or hotracing.
09-02-2010, 01:22 AM | #5 |
Rock Stacker Join Date: Mar 2010 Location: Alaska
eBay has tons of Clodbuster parts as well. Not as good as supporting a vender. But works in a pinch. Just picked up a sweet Clod custom roller two days ago . I saw everything from axle housing's and pinion gear's. To a complete bearing set and locker's.
09-02-2010, 03:49 AM | #6 |
Yeah, Im gonna give it a shot to build some axles. time to open up the wallet a bit.
