04-09-2006, 07:22 PM | #41 |
Quarry Creeper Join Date: Dec 2005 Location: NH
love it man I jus love it! its the most original thing Ive seen since well I dont know but its so original that it kicked the original "most original" things *** and took its place! I love it!!!! Major Props! -RR |
06-12-2006, 08:46 PM | #42 |
Rock Stacker Join Date: Mar 2006 Location: columbus
So I took the truck out today, it has been a while. I forgot how to drive, the rear steer was bacwards....... Overall the truck was fine except for when the screw broke that holds in the upper rear links and then pulled out of the gear case:-( It is an easy fix, and I am just happy that the parts that I fabbed did not break. |
06-13-2006, 01:20 PM | #43 |
just when you think youve seen everything......
08-07-2006, 08:35 PM | #44 |
Have you fixed this thing yet? I wanna see more video of it too. |
08-08-2006, 11:26 AM | #45 | |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
Great idea! cant wait to see more on how it works! | |
08-08-2006, 12:20 PM | #46 | |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
08-08-2006, 03:21 PM | #47 |
Ha ha I have not touched the thing since it broke 6/12/06. I keep thinking about fixing it, maybe today will be the day. I have a new dodge dakota body for it but it is not painted yet.
08-08-2006, 06:12 PM | #48 |
Ok, I fixed it and I think I improved on the original design of the upper link assembly. Originally the post that connects the upper links had one machine screw and one pin holding it into the dif case. When I took the post out I noticed that the pin hole was threaded so I made a bottom hold down that eccepted two machine screws. The problem is that the heads of the machine screws overlap eachother so my solution was to put a washer under one of the screws which it kind of but not really double nuts the assembly. Here are some pictures YO: Making the bottom hold down Bottom hold down with one machine screw Bottom hold down with both machine screws Last edited by rupps5; 08-08-2006 at 06:38 PM. |
08-08-2006, 06:39 PM | #49 |
the video is gone.... got any more? linky no worky |
08-09-2006, 01:46 PM | #50 | |
I also plan to take some more video footage of his truck whenever he's ready to go for a drive. | |
08-12-2006, 07:50 AM | #51 |
The wheel base has been shortened by about an inch and I think it climbs better. I just shortened the front links and not the rears so the weight bias moves forward. I have some pics that will be posted up later.
08-12-2006, 09:01 AM | #52 |
I agree, it did seem to climb better. It seems a shorter wheelbase is possible as long as the weight is low, and that's good because that makes center clearance not as important. Here's a few pictures. |
08-13-2006, 10:21 AM | #53 |
08-13-2006, 11:00 AM | #54 |
Hell's Gnome Join Date: Jun 2006 Location: I'm mean because you're stupid.
I guess I'm being silly, but, what problem is to be solved with cable steering? Is it just to try something different?
08-13-2006, 11:14 AM | #55 |
It was first because the servo would not fit anywhere, and second because it was something different. It is pretty cool to mess with and watch work.
08-13-2006, 05:00 PM | #56 |
Fot those of you that do not like youtube, the video is also hosted on yahoo video here: http://video.yahoo.com/video/play?vi...10764fb.698509 |
08-14-2006, 10:34 AM | #57 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
Giant scale servo's can't fit on a Clod axle brace? http://cgi.ebay.ca/Hitec-Giant-servo...QQcmdZViewItem They can and do.... |
08-14-2006, 01:36 PM | #58 |
Those mounts will not work with the upper links post that I am using.
08-15-2006, 07:46 AM | #59 |
I tried...;) They were something I was looking at for adding to my Gecko as to NOT hafta buy expensive servo's...
