02-01-2011, 06:19 PM | #1 |
Pebble Pounder Join Date: Sep 2010 Location: SD
| What are good motors for a nice quick clod
Hi, I've done my research, but I can't find anything that is a sure bet. Back in the day, a couple of trinity 19T speed gems would be the best answer. What is the best answer today? I want a fairly fast clod with some like 19Turn motors and possibly run a 11.1 lipo.. Any thoughts? seems everything has gone brushless anymore... |
02-04-2011, 10:56 AM | #2 |
bump. How about some 19x2 Orion Method Rs? |
02-04-2011, 11:15 AM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
You have to remember that 1 motor needs to be reversed. You can reverse the Orion motor simply by rotating the endbell 180 degrees. The 19x2 motor should be pretty decent for your needs...
02-04-2011, 12:08 PM | #4 |
How are the Venom fireballs? I know they are cheap in price, but do they out right suck for a clod? I imagine I would reverse the venom the same as the orion. Thx |
02-04-2011, 12:26 PM | #5 | |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
Venom Fireball motors suck. The Orion Method R line of motors are better and about the same price. Might want to even bump up to a 17x2 for a bit more speed. | |
02-04-2011, 09:06 PM | #6 |
| i was thinking about that. Not really sure why I'm stuck on the 19x2... but i want a nice solid balance between speed and power. I'm not sure where that sweet spot is on a clod (its been 13 years since I had my last clod, and I have no clue what motors I ran). I'm thinking about the Orion Method R either 19x2 or 17x2 with the CC Sidewinder SV2 ESC.... |
02-04-2011, 09:47 PM | #7 |
17T motors with 13T pinions will give you a good combo of power and speed, without needing to bump to a super-expensive ESC.
02-04-2011, 11:33 PM | #8 |
I'm having a hard time finding any reliable specs on the Sidewinder SV2.... I think I'm going to lean that direction, but I dont know if that one ESC can handle two 17 or 19 turn motors... |
02-07-2011, 02:07 AM | #9 |
Quarry Creeper Join Date: Sep 2004 Location: Honolulu, HI
I run 15t HPI fireball motors in 2 of my CLods. On has a Novak Superduty and the other has a Super Rooster.
02-10-2011, 11:18 AM | #10 |
I dont believe Novak makes brushed ESC that can handle lower motor limits like the super rooster used to... So, looks like the CC SV2 is my best bet. |
02-10-2011, 12:56 PM | #11 |
The Super Dutys are (or were) available through Novak remanufactured for like $55. That's a steal for those.
02-11-2011, 02:05 AM | #12 |
Newbie Join Date: Feb 2008 Location: AK
<P>Speaking of motors, i've researched a while back and came up with nothing for running a brushless dual motor setup. Like the traxxas system. I didn't know how it would be wired up if at all possible. Anyone running something like this?</P> <P><BR>Also, i got more "gear whine" in one axle then the other. Anyone got a cure? I've tried switching the motors and no change. All brand new gears. I've even added automotive grease for "lubrication".</P> <P>Thanks in advance y'all. No intention of hijacking the thread, just havent had any luck on these subjects.</P> <P>~Johnny</P> |
02-11-2011, 08:51 AM | #13 | |
I just checked this out, and the Super Duty doesn't appear to support LiPos... or more accurately, it doesn't have LiPo cut off. I think I will just stick with the SV2 sidewinder, I just wish I knew for sure if it could handle a couple of 19s without issue... There isn't any information on that. | |
02-14-2011, 10:34 AM | #14 |
Rock Stacker Join Date: Dec 2006 Location: eaton
if you can find a mamba max it will run either motors you mentioned also a holmes hobbies brxl will do the job
02-15-2011, 11:18 AM | #15 |
