| | #1 |
| Newbie Join Date: Mar 2006 Location: Yankton
| Ok i give up....what are the upper mounts for a stick? I have searched numerous sites and stores tring to find something similar but to no avail...( yea that means i Searched this one too) Where do you find these links? |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: Mar 2005 Location: Nicholasville
| I have seen alot of people use commom L brackets for shock mounts....but I cut mine out of 1/4" X 1" aluminum stock from Lowe's....thay look just like the one's on the real thing...just not as pretty..*LOL*....it only took me 46,528 times to get 2 that were exactly the same... Dave |
| | #3 | |
| OCCUPY RCC! ![]() Join Date: Dec 2005 Location: I am the 53%.
| | #4 |
| TCS/Holmes Hobbies ![]() Join Date: Feb 2005 Location: Burnsville
| This thread might show you what you need: Project Xerox (If you can't beat them, join them!) And the ball joint is also known as a heim joint or heim for short. McMaster has them listed as: Lightweight Nylon Ball Joint Rod End 7/16"-20 Right-Hand Male Shank, 89 lb Load Capacity Nylon Composite Ball Joint Rod End, 7/16-20 UNC Male http://www.mcmaster.com/ #1064K551, $8.15 ea |
| | #5 |
| Thanx for the info guys. I am curious has anyone used a different variation of the heim? That would be interesting to see the different home depot methods thought up! |
| | #6 | |
| Newbie Join Date: Apr 2006 Location: valencia
| | #7 |
| Rock Stacker Join Date: Dec 2005 Location: MISSISSAUGA
| | #8 |
| Hey i found a good one for homebrewers. Try lawn mower ball joints. They come in like two sizes that i found. The 3/8's work very well a little tall but they work nun the less. It crawls well i just need to find a decent spot to do it. The place i was going has WAY to many drop offs and overhangs to actually enjoy it without wondering if you broke anything on the last hit...Ill post pics when i get em and thanx for all the input! |
| | #9 | |
| Rock Crawler Join Date: Jan 2006 Location: Stuttgart
| Thread Tools | |
| Display Modes | |
