Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: Clod hex to 23mm hex adapters?
Old 05-02-2006, 02:22 PM   #1
Default Clod hex to 23mm hex adapters?
Does anyone make one single adapter that does this?
I've seen all of the stuff on the board and it seems like you have to buy 2 adapters to do it. And even at that it sounds like you have some clearance issues with the wheels.
I can't believe that no one makes a one stop solution to the problem, a clod hex to a 23mm hex with the right backspacing to take care of the issue with the narrower wheels.
Can anyone help me?
Thanks
mschaffer66 is offline   Reply With Quote
Old 05-02-2006, 02:28 PM   #2
Highmark showed me this on www.sercrc.com :
http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=46027
$18.88
x 2____
$37.76
+ $4.09 shipping
$41.85
Not all that cheap... Click the image to open in full size.
raytard is offline   Reply With Quote
Old 05-02-2006, 03:03 PM   #3
Can anyone help me?
Thanks
The outter stub shaft is not long enough to provide the "right" backspacing. Bender is the only guy I know of that makes an adapter worth a **** for this application.
DirkDigler is offline   Reply With Quote
Old 05-02-2006, 03:05 PM   #4
Makin "Bank" in ND!!
racerx's Avatar
I got the Bender customs adapters and they work great! You do have to narrow the wheels though, very easy to do. His parts are some of the best machined aluminum and delrin stuff I've used you won't be disapointed .
racerx is offline   Reply With Quote
Old 05-02-2006, 03:08 PM   #5
You could also switch over to TXT stub shafts and Benders TXT adapters and get a little more width but you'll still have to narrow the wheels, I think.
Old 05-02-2006, 03:29 PM   #6
Location: Driving the Troysion Stick up the BIG BOY line!
I use TXT stub shafts and Benders TXT 23mm adapaters on my clod with a rim that is narrowed to just under 2" Here is a picture of it. Of the stance.
cheapjeep2 is offline   Reply With Quote
Old 05-02-2006, 04:19 PM   #7
~The Scale Shop~
STANG KILLA SS's Avatar
$18.88
x 2____
$37.76
+ $4.09 shipping
$41.85
anyone use these "hobby etc" ones?
or with the bender ones can u use these "stock" narrowed wheels?
40 Series Cheyenne Bead-Loc Narrow 23mm HD Hex Wheel
Gold Rings Part #2683-01
Pro-Line now offers a narrow version of the bead-loc system in the ever-popular Weld Racing Cheyenne design exclusively for the 40 Series Moab XL tire.
http://www2.towerhobbies.com/cgi-bin...?&I=LXLPW9&P=7
STANG KILLA SS is offline   Reply With Quote
Old 05-02-2006, 08:08 PM   #8
which site is bender? I really need to get these on order. I've got the rims, tires, chassis, and almost all of my electronics. Once my axles show up i'll have the whole package.
Old 05-02-2006, 09:21 PM   #9
Team *
62PYRO's Avatar
Even though these are narrower,the width is taken out of the front mostly.You will still have to narrow them.For the money,I don't think you'll find much better adapters than Benders.
62PYRO is offline   Reply With Quote
Old 05-02-2006, 09:26 PM   #10
Team *
62PYRO's Avatar
Go into the general vendors section and search for Bender.then check 23mm adapters.
Old 05-02-2006, 11:54 PM   #11
2006 2.2 National Champ
BENDER's Avatar
You can see my 23mm adapters on my website.
http://www.bendercustoms.com/acc.htm
Here' a link to my Vendor's thread here on RCC.
BENDER Customs 23mm adapters...........Last 5 sets then they're gone
The Commando wheels will give you a little wider stance then the Cheyenne bead locks. Either way I would narrow them down to about 2" wide.
BENDER is offline   Reply With Quote
Old 05-03-2006, 09:35 AM   #12
Thanks Bender, i've got a set on order.
Do you offer anything else in replacement for those black outer washers? Something more blingy?
Old 05-03-2006, 10:12 AM   #13
just put the chromed cap back on the wheels. THey come with the PRoline wheels.
Old 05-03-2006, 08:04 PM   #14
BENDER's Avatar
I got your orders, thanks.
I don't offer a different outer washer. As Dirk suggested, you can use the "chrome" center cap supplied with the beadlock wheels.
