| | #1 |
| Newbie Join Date: Apr 2006 Location: australia
| this should probably be a newb question but what size and length are the bolts that attach the motor too th gearbox on a 55 turn lathe going into a clod |
| Sponsored Links | |
| | #2 |
| RCC Addict ![]() Join Date: Oct 2005 Location: Trussville, AL
| the holes should line up and fit a 3mm screw but if you are running a lathe then you will probably want to get an adjustabel motor mount so that you can positon the pinion flush against the gears |
| | #3 |
| Newbie Join Date: Jan 2006 Location: St. George, UT---Used to be Playa Del Rey...
| The length of the screw or bolt needs to be 30 mm long. |
| | #4 |
| Quarry Creeper Join Date: Jul 2005 Location: Utah
| Ya you know that because I looked in the book for you!!!! |
| Thread Tools | |
| Display Modes | |
