Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: Aluminum Clod Axle Parts
Old 01-27-2012, 07:25 AM   #1
Default Aluminum Clod Axle Parts
We use to only have JPS Aluminum Axle tubes, C's and Knuckles. I see Integy
is making some of this stuff. Is it any good? I there anybody else out there making this stuff?
Wheel_Works is offline   Reply With Quote
Old 02-19-2012, 08:04 PM   #2
Default Re: Aluminum Clod Axle Parts
I've got Integy parts on my clod (axle tubes, knuckles, locked gear sets, gear boxes) including the gear set with their spool, I haven't had any issues with the aluminum parts other than I couldn't use my CPE rear steer lockouts and had to make up some linkage to hold the knuckles. The gearset on the other hand would not mesh properly without adjustable motor mounts. I just switched back (to plastic) the aluminum gear that meshes with the pinions and all was good. I still have to install the gearboxes but they seem to be a direct copy of the original casting, not 100% sure though you never know with integy until you get it all put together if everything works proper.
cagedcbr is offline   Reply With Quote
Aluminum Clod Axle Parts - Similar Threads
Axle Aluminum Parts Man of 5lay Axial AX-10 Scorpion 9 07-08-2011 04:18 PM
Axial Aluminum Axle Parts Axial Axial AX-10 Scorpion 43 10-23-2008 08:45 AM
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
