04-21-2012, 12:30 PM | #1 |
Newbie Join Date: Mar 2012 Location: Stourbridge U.K
| 6 X 6 terra-pup
Hi Guys, New to the Forum, but i thought i'd show you a Build i started a few weeks ago. No expensive spending on this. Started off with a home built Chassis and a pair of Axles Had an old E-Savage ESC which was used to check the Gearboxes with and all was working fine Front Axle was added and rough alignment done Spent a few hours setting the suspension up, but still needs work on it. Still got plenty to do on her but this is where i'm Aiming to get, Colour yet to be determined. |
04-21-2012, 12:33 PM | #2 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
| Re: 6 X 6 terra-pup
Like , crawler hueler.
04-21-2012, 12:37 PM | #3 |
| Re: 6 X 6 terra-pup
Hopefully this Link works for a short Running Vid before i put the Suspension on. Clod Truck 6 X 6 - YouTube |
04-22-2012, 03:58 AM | #4 |
Newbie Join Date: Mar 2012 Location: Netherlands
| Re: 6 X 6 terra-pup
Cool build man, i'm following this one. for some reason the more axles the more i like |
04-22-2012, 11:38 AM | #5 |
| Re: 6 X 6 terra-pup
Thanks guys, still struggling a bit with the steerig tho' Axles widened approx 15mm either side and with a 20kg servo she still seems lazy ? Should the Tyres have a foam in them as it could be there's so much Rubber on the Ground.
04-23-2012, 12:20 AM | #6 |
Rock Crawler Join Date: Feb 2011 Location: Courtenay
| Re: 6 X 6 terra-pup
Are you hoping this rig will float? kinda like the 1:1's do? Then I would try and do a low air pressure in the tire, rather than foam.
04-23-2012, 12:22 AM | #7 |
Newbie Join Date: Mar 2012 Location: Upstate NY
| Re: 6 X 6 terra-pup |
04-28-2012, 05:11 PM | #8 |
| Re: 6 X 6 terra-pup
Well started the Body, long way to go but it's a start ! Need to cut 1/2" off the bottom of the front ( little to deep ! ) |
04-28-2012, 07:57 PM | #9 |
Pebble Pounder Join Date: Sep 2011 Location: perth wa
| Re: 6 X 6 terra-pup
dude the the coolest thing done yet to some clod axles just wow also try see if you can fit a rc in bed like a 1/16 or something any way cool build I'm watching this for sure
04-29-2012, 07:02 AM | #10 |
| Re: 6 X 6 terra-pup
Well Guys a few hours spent on her today. Windows Cut Doors Hinged. Unsure about cutting rear Quarter windows tho' ! yes/no ??? Anyways a few more Pics. jesseRS10comp, Can fit a 1/8 Buggy ion the Bed it's so Big !!! |
04-29-2012, 07:25 AM | #11 |
| Re: 6 X 6 terra-pup
wow man once its built up put your trucks or car on it and shoot some video and good luck with the build i will follow this one
05-01-2012, 01:11 PM | #12 |
| Re: 6 X 6 terra-pup
And a bit more ! front end and wheel Arches done in Styrofoam, Hinges for doors arrived through the post this morning. Lighter next to wheel for proportion. Thinking this is more 1/6th scale than anything else now ( well at least i can use Action Man Figures now ! ) |
09-20-2012, 01:33 PM | #13 |
Newbie Join Date: Apr 2011 Location: Montague
| Re: 6 X 6 terra-pup
This thing makes the clod tires look SMALL!
09-23-2012, 09:08 PM | #14 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
09-23-2012, 09:14 PM | #15 | |
| Re: 6 X 6 terra-pup Quote:
20kg servo should be more than enough to turn stock clod tyres, but you might need to get an BEC to power it properly otherwise it wont be as strong as it says on the box Castle creations CC-BEC is one of the best and also smallest BEC's, but you can get cheaper ones that will do just as well. They are however often bigger, but I dont think space is going to be an issue for you With a stack of spare aluminium and 6 spare clod axles on my shelf, I'll be watching this build closely | |
6 X 6 terra-pup - Similar Threads | ||||
our new pup. .. . for now. | IDnewcrwlr | Chit Chat | 9 | 12-16-2009 12:25 PM |
New pup | wrx-n-ktm | Chit Chat | 11 | 03-03-2007 03:33 AM |
