07-19-2006, 05:00 AM | #1 |
Newbie Join Date: Aug 2005 Location: nethelands
| Lenght of links
Hi, can different lenght of upper links and lower link become a problem for the suspension on my clod ?? Greetings Dragon |
07-19-2006, 08:12 AM | #2 |
Newbie Join Date: Jun 2006 Location: Fresneck
As long as they don't bind and/or adversely affect your axle position/angle you should be fine.
07-19-2006, 08:58 AM | #3 | |
Where are they mounted on the chassis? Are they parallel with each other? Hows the trianglation setup? There are many things that can effect your suspension other than just different length of links. | |
07-19-2006, 09:48 AM | #4 |
the mounts on the chassi are parallel above each other and the chassi is approximately 90 mm wide. Edit: |
07-21-2006, 02:41 AM | #5 |
*bump*
07-21-2006, 06:12 AM | #6 |
Quarry Creeper Join Date: Apr 2006 Location: winchester
how long are the links on a stick chassis?
07-21-2006, 08:16 AM | #7 |
i dont know.
07-21-2006, 08:58 AM | #8 |
just make sure that when your links connect that your steering is vertical and not leaning forward or back!
07-22-2006, 08:25 AM | #9 |
i am making these links bit how do i know precise where the center of the tube is ?? is there some thing for ?
07-24-2006, 12:51 PM | #10 |
i have tryd to drill in the end of the tube but i never get the hol in the center of the tube. does some one have any good tips ??
07-24-2006, 03:17 PM | #11 |
Pebble Pounder Join Date: Sep 2005 Location: minocqua
i think that should become a sticky or tec tip, great info and very clear pics, good job.
07-24-2006, 07:23 PM | #12 |
Hmm, never thought of making links like that with the all thread all the way through. Keeps from having to thread the tube or worse yet weld the nuts to the ends of the tube...nice job. |
