Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Clod-Honcho
Old 06-01-2012, 02:15 AM   #1
Default Clod-Honcho
i started this build a week ago using a pile of clod & Axial parts aswel as some of my custom stuff.
x2 Clod axles - locked using CA
custom rear-steer lockout using cladboard & links
Axial AX10 lower links
Piggyback alloy shocks - brand n/a
Axial rocksliders
Custom TVP chassis - steel
Custom framerail - alloy
Axial Honcho lexan
Stock wheels w/Duratrax v-spike tires
Thundertech wheel widners
Thundertech adj motor mounts
custom top links - 3mmthread rod & 3/16 alloy tube
TRX EVX2 ESC
AE Rx
AE Tx
AX2 servo (metal gear & bearings)
custom lower link mounts - alloy
custom servo mount - steering
Axial batteryplate & velcro straps
N-Savage alloy bars (TVP supports for Clod)
N-Savage plastic bars (supports battery plate)
Axial scx10 rear bracing for framerails
*still looking for something (thinking plastic if not alloy) 10mm thickness for my custom 3-link post mounts (not fabb'd yet, but designed *not shown yet*)
RC4WD steel bumper with tow hooks
Still waiting on the rear tube cage from Axial that fits this Honcho body to arrive?
ive been reading the forums re:
motor stall
DIG
those interest me, and ill dig more into this as time permits. Work & kids.....
Torredo is offline   Reply With Quote
Old 06-01-2012, 06:10 AM   #2
Default Re: Clod-Honcho
Good looking truck! I didn't see what motors you will be using?
Keep the updates coming!
calcagno45 is offline   Reply With Quote
Old 06-01-2012, 07:47 AM   #3
at the moment it is using the 540sh motors until i can find some nice 55t-60t motors at my lhs.
atleast i can run it but i doesnt have the low down Tq by any means.
Old 06-01-2012, 05:53 PM   #4
Sounds good. I'm debating 45t or 55t motors in my clod. But I do think I'll go with 55t and run them on 3s.
Old 06-02-2012, 10:16 PM   #5
Started on my E-DIG and got the servo mounted to my skidplate and the wiring all worked out. All i need is a 24v slide-switch and i can get this sucker DIG'n
Lookin under the chassis
Servo/skidplate *not yet installed on the chassis until i get the switch on monday.
Also note: the switch shown in pic cannot be used!!!!
Old 06-21-2012, 06:42 PM   #6
Keeping in mind this is mocked up for now, i had to make sure it all worked good first.
Clod now has longer wheelbase by inverting the upper/lower links.
*Chev body seen in pics are temporary until i recieve my ordered 1980 Proline bod, painting it black.
Servo box now on framerail
SwampDawg is offline   Reply With Quote
Clod-Honcho - Similar Threads
5 Trucks - Honcho, 6x6, Clod Buster, Defender Night trail at Woodgrove Ave RC Trail boolean21 Scale Videos! 2 07-31-2011 07:25 AM
