![]() | #1 |
Well it's been a busy week ![]() ![]() ![]() Last edited by cartronicshn; 02-19-2007 at 07:28 AM. |
![]() | #2 |
i must say i have hot glued, jb welded, diffs in the past, but have really enjoyed these diffs lockers, they are so easy to work with and really fast ![]() ![]() ![]() ![]() |
![]() | #3 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
I can't really tell if the chassis is complete or not from the photos, but the lower 4-links should mount to the upper portion of the axle tube (with the metal gearcase supports) for optimal ground clearance. Good luck with the rest of the build!
![]() | #4 |
Brett, thaks for the heads up ![]() ![]() |
![]() | #5 |
![]() | #6 |
Rock Crawler Join Date: Apr 2006 Location: louisville
nice id like to see it runing and if theres any wheel hop
![]() | #7 |
i'll finish it tomorrow ![]() ![]() |
![]() | #8 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
nice axles:-P
![]() | #9 |
look familiar eh? ![]() ![]() |
![]() | #10 |
cant says i do
![]() | #11 |
got another set from e-bay for $112, included the front aluminum knuckles from rc4wd ![]() ![]() |
![]() | #12 |
Rock Crawler ![]() Join Date: Apr 2006 Location: Salem, Orcrc
wow, thats good for 112$
![]() | #13 |
finally some action pictures of a test run, took the gmade wheels and tires out and put the moab xl what a difference ![]() ![]() |
![]() | #14 |
some more ![]() |
![]() | #15 |
looks good let me know if you have wheel hop problems with it
![]() | #16 |
oh i haven't finished it yet, i have to add weight to the wheels ![]() ![]() ![]() |
![]() | #17 |
How do you like the 75t motors?
![]() | #18 |
the 75 have a lot of power, i thought with 13 tooth gears it would be to fast to crawl but the motors did help to bring down the speed a lot, i will put 8 tooth on it as soon as my adj mounts come in and will use a 8 cell stick ![]() ![]() |
![]() | #19 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
how does it do with no shocks?
![]() | #20 |
it has suspension through the tension bars in the middle of the chassis, it is very predictable to drive, you would have to try one to really appreciate it against the normal shock set up, i can definetly see the difference between my NN and THE CLAW ![]() |
