Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: What speed can you get from clod axels
Old 08-05-2006, 05:16 PM   #1
Default What speed can you get from clod axels
i am wondering what is the max speed i could get out of them and what gearing would be needed
creator_7 is offline   Reply With Quote
Old 08-05-2006, 05:21 PM   #2
As fast as your wallet will allow.
polyophio is offline   Reply With Quote
Old 08-05-2006, 05:30 PM   #3
Thats no joke. With 55t lathes, 9/8 tooth pinions, and a 8 cell battery I can already get the front to pop off the ground when accelerating. And thats with the majority of the weight over the front axle. Go with a brushless system and gear it high and that thing should fly.
TxCruzr is offline   Reply With Quote
Old 08-05-2006, 05:47 PM   #4
do you think the gears can handel a high speed mamba brushless motor
i was wanting to do this to a truggy but they seem very flimsy and dont handel mambas very well and i see the clod axels are very ruged and look like the can take a beating i am going to make a speed clod and i want to see how fast i can get it to go
Old 08-05-2006, 11:49 PM   #5
Bolt in a pair of nine turn mod motors, and it will haul a$$. Just turn the endbell on the rear motor 180 degrees, so the timing is right. Probably won't get much run time, but it will be fun while the batteries last (or you hit something).
todd1803 is offline   Reply With Quote
Old 08-06-2006, 12:55 AM   #6
yeah, put those in and some 20tooth pinions, thats go FLY, if your worried about the gears then get some aluminum ones in.
clod booster is offline   Reply With Quote
Old 08-06-2006, 08:17 AM   #7
Get two RC4WD twin motor clod axle's, 4 brushless motors, and 4- 4cell lipos.... and hold the hell on
Varv is offline   Reply With Quote
Old 08-06-2006, 02:32 PM   #8
heres what you should get:
rc4wd twin motor clod gear boxes
rc4wd aluminum gears
rc4wd thundertech ball diff
4 novack brushless systems
4 4cell LiPo batteries
4 21tooth pinions
ball bearings
tq3 3channel w/ rear steer
Old 08-07-2006, 02:44 AM   #9
Nope..
Brainstain's Avatar
I needed some wheel speed so I wired my EVX up for 14.4 and I GOT IT. For having lathe motors and 9 tooths it hauls balls. It's about as fast as my g/f's nephews stock pede.
Brainstain is offline   Reply With Quote
Old 08-07-2006, 03:28 AM   #10
CLODZIRRA's Avatar
Ain't that the truth...
CLODZIRRA is offline   Reply With Quote
Old 08-07-2006, 07:56 PM   #11
Are you on crack? holly chit... I don't think I'd want a truck that would move that fast to turn on a dime... stick with just frong wheel steering... it would be all over the place with 4ws...
As for the gears.. theres no slipper so you better go aluminum.. and some beadlock rims, and glue the tires anyway, and the foams.. and lock tight the wheel nuts on... b/c its going to be stupid fast...
Old 08-07-2006, 09:41 PM   #12
god why dont you just weld the whole damn thing together
Old 08-08-2006, 07:58 PM   #13
lol thanks guys do you think the nn frame couls hold up to the spped and power of the motors
also i want to use the new mamba max for big trucks coming soon
will think about the 4 motor thing
also will it work if i just had rear wheel drive
Old 08-08-2006, 10:01 PM   #14
go with 4wd, youll wish you had it when you dont
Old 08-08-2006, 11:22 PM   #15
Are you serious? Are you talking from a standing start, or from reverse?
Mad Scientist is offline   Reply With Quote
Old 08-09-2006, 04:28 AM   #16
Nope..
Brainstain's Avatar
Mine will do it from a standing start on 14 cells
Old 08-12-2006, 12:19 PM   #17
I'm sorry, I just don't see how 4 motors are going to go faster than 2 motors, it might accellerate slightly faster but the top speed is going to be the same. You could have 100 motors and the top speed wouldn't change, also I don't think anyone needs two brushless motors on a clod axle, thats just silly. That's going to be a $2000 undrivable accident waiting to happen. Get a nitro truck if you want speed.
BTW i ran the stock cans with 8.4V with proportional rear steer and you couldn't keep the roof off the ground.
Kamikaze is offline   Reply With Quote
