Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: what size
Old 08-11-2006, 08:08 AM   #1
Default what size
i have a cuple of questions i want to make a chassie out of c channel and dont know what size to go for and how do i mount the 4linke to the stock axles if any one has a pic on how to do this plz help i would like your help
freeclod is offline   Reply With Quote
Old 08-11-2006, 08:36 AM   #2
Sorry, haven't got any pics, but most people use the screw hole that attaches the axle brace to the stub axle for mounting the lower links, and for top links use the big tube in the center of the axle. Hope this helps.
4link4eva is offline   Reply With Quote
Old 08-11-2006, 09:10 AM   #3
could you mount them to the axle stays and to or not
Old 08-11-2006, 09:35 AM   #4
You could but I think they would be too high in relation to the top links
Old 08-11-2006, 10:27 AM   #5
THis is what i did with my clod axles, I put one long bolt on each side behind the hub there were already two holes because of were you put the screws in for the axle brace and i put longer ones there and put a spacer and then my link and another spacers and a nut i did that 4 times, for the 4 link two be complete, you must get or make some top link mounts that go in the whole on top of the axles. This might be confusing i wish i had some pictures. Pretty simple to do, although there is other ways!
Some were someone sells a mount that you somehow mount to the axle and it has a way to mount it for the four link and shocks, i will look.
EDIT: here they are
http://www.thecrawlerstore.com/suspension.html
The top link mount set of two
and Gmade brace mount set, that will have your 4 link mounting point takin care of, adn shock mounting points
scalecrawler is offline   Reply With Quote
Old 08-11-2006, 10:37 AM   #6
The NN mounts the bottom links as scalecrawler did his, with the longer bolt through the axle C and the axle brace. For the upper links there are a few places that make a mount that bolts through the tube on the front axle for the upper links.
Here is TheCrawlerStore's.
TxCruzr is offline   Reply With Quote
Old 08-12-2006, 05:41 AM   #7
Whatever you do, don't buy your top link mounts! I made mine out of a sheet of aluminium, and they are perfectly centred. People sell them for $30+ and I made mine for free: rip off
